04-30-2016, 02:30 PM | #1 |
70+ ( Old Skool Club )
Upper Rad Hose question
This is the second truck I've sen with this setup for an upper rad hose. Is this correct/original with a piece of hose at manifold neck then a steel tube then an hose to top rad connection?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-30-2016, 02:40 PM | #2 |
Re: Upper Rad Hose question
i do believe only 4x4's came with the upper steel tube.
that is a pic of a 4x4 truck...notice the c member. i dont know exactly what years they did or didnt use them but my 71 has one.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-30-2016, 03:06 PM | #3 |
20' Daredevil (Ret)
^^ What he said, OEM on 4x4s. My '72 K20 has it.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-30-2016, 03:17 PM | #4 |
Yes its from a K2500 GMC, Thanks for the info. Now I wonder why it was done this way.
04-30-2016, 07:42 PM | #5 |
20' Daredevil (Ret)
Something about the possibility of a long rubber hose sagging and making contact with the alternator belt.
04-30-2016, 09:30 PM | #6 |
The engine on the 4 wheel drive trucks sits WAY back compared to the 2x4 trucks. This is so they can get enough length on the front driveshaft. Notice the deep fan shroud as well.
04-30-2016, 11:11 PM | #7 |
Thanks for the info. There is always something learn about these trucks.
05-01-2016, 09:12 AM | #8 | |
FWIW, my '69 K10 still has the tube.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
05-01-2016, 10:53 AM | #9 |
Yeah, when you have to rotate the oil pump drive with a screwdriver to line things up and you have a 4" lift and 35's it gets contortionist interesting!
05-01-2016, 02:16 PM | #10 |
20' Daredevil (Ret)
Which is exactly why I converted to HEI back in the early Eighties...
