05-03-2016, 12:12 AM | #1 |
Big Block Swap For Trailer Towing
Thinking about putting a big block in place of the 283 in my 1966 Suburban. Been towing a 27 foot dbl axle camper trailer and feeling the limitations of the 283 small block - "it's time to put a bigger motor".
Looking for comments regarding ease of fitment, references to example threads that may be out there, suggested motor/auto-tranny combo. Not looking for the Corvette super motor, just a good old fashioned big block with carburetor. |
05-03-2016, 02:06 AM | #2 |
Re: Big Block Swap For Trailer Towing
Pretty much what we did...BBC/T400/D60.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
05-03-2016, 09:59 AM | #3 |
05-21-2016, 03:57 AM | #4 |
You will probably need to modify the firewall to get a big block to fit in there. One day I'm going to put up 350 in mine. Pretty much A drop in motor swap.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
05-22-2016, 01:11 AM | #5 |
60-66 Nut
You do not have to modify the firewall. You just need to move the engine forward with either the '68-'71 big block engine mounts and brackets, or the '73-'87 engine mounts. The '73-'87 frame brackets from a C20/30 fit the earlier frames better than the C10 brackets.
I did not modify the firewall on my '66 Suburban, but I did fabricate some custom engine mount brackets that moved the engine forward about 2" from the original location.
06-29-2016, 04:43 PM | #6 |
Big block fits no problem either way as long as you use factory valve covers. Larger aftermarket chrome or aluminum covers will need more clearance. I am running 454/700r4 combo.
