Old 05-07-2016, 04:47 PM   #1
VonDog
VonDog's Avatar
Warn hub dilemma???
Taking apart my hub today and can't seem to get the main gear out. Here's whats going on: pulled the snap ring and the lg retainer, pulled out the inner gears and put the Allen head screws back in a little for leverage to pull out the main gear but can only wiggle it in and out slightly. Found some small broken pieces of metal inside. Am I missing a step? Can't see anything that might prevent me from pulling it out. I shot a short video but can't upload it. Any ideas???
60 K20, eaton HO52, T221, SM420, Dana 44 closed
78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open
05 Dodge Ram 2500 5.9 Cummins 4x4
VonDog is offline   Reply With Quote
Old 05-07-2016, 05:57 PM   #2
VonDog
VonDog's Avatar
Re: Warn hub dilemma???
Here's the parts removed.
Old 05-07-2016, 06:02 PM   #3
VonDog
VonDog's Avatar
And a better shot of what won't come out
Old 05-07-2016, 11:21 PM   #4
Brad54
Brad54's Avatar
Never having taken one apart before, I'm going to bet that flat ring with the four notches has to be unscrewed.
MAC, Snap-on and other companies sell a Dana 44 front axle socket that's got four teeth on it. My guess is that socket engages those notches, and you unscrew that ring, which is holding the pieces in.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 05-07-2016, 11:33 PM   #5
kippnidaho
kippnidaho's Avatar
There is a socket with four teeth on it that loosens the lock nut. Then you can pull it apart. That nut is what tightens the bearings there is also a washer and another nut behind that I believe.
KippnIdaho
Twin Lakes, Idaho
1966 K10 SWB Stepside
2003 Jeep Rubicon
2011 Camaro SS Rag Top
kippnidaho is offline   Reply With Quote
Old 05-07-2016, 11:49 PM   #6
padresag
there is probably a burr on the inside of the hub that is holding it back, just give it a little tap in with a hammer and see if there is come crap holding it up, here is a picture of a new one so you can see that there is nothing holding it. those lock rings just retain the hub and bearings
you can also google warn hubs and find a lot of info. if people serviced their front hubs more often they wouldn't have any problems
ron
padresag is offline   Reply With Quote
Old 05-08-2016, 09:38 AM   #7
VonDog
VonDog's Avatar
ron
Yep, that's what I figured too with all the small pieces of metal in there. Time and pressure back and forth plus shooting air and degreaser plus perseverance equals success The PO gave me slightly used hubs and said 1 needed replacing. Thought it'd be 15 minutes but turned into 5 hours. He neglected the brakes too, rotors need turning, needs pads, bearings and seals so I think I'll do a complete rebuild. Oh Boy
