Old 05-08-2016, 07:57 PM   #1
chastain90
chastain90's Avatar
Throw out bearing or clutch?
Drove my Blazer for the first time today in quit a few years. It would not go in gear at first and I had to depress the clutch and push it back in and then it started making a whining grinding noise. Then while driving it just stayed and never went away. Just went slow around the block trying to test everything out. When I would stop I sometimes had to push the clutch twice to get it back to 2nd. I know grinding could be the throwout bearing but maybe I need both? If so, what brand and place is the best for these trannys? Sm465.
chastain90 is offline   Reply With Quote
Old 05-12-2016, 12:48 AM   #2
69-72
69-72's Avatar
Re: Throw out bearing or clutch?
Maybe things were just seized up from sitting, give it another drive.
Might as well do the whole deal, no point replacing just the bearing for all that effort. I got a luk gold clutch kit from Amazon. Seemed to be the best price for a quality kit. . You will need to have the flywheel resurfaced too.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 05-12-2016, 10:38 AM   #3
chastain90
chastain90's Avatar
Thanks, I seen a post where summit part numbers were gave. It was the whole kit, clutch pressure plate and throwout bearing.
Old 05-13-2016, 09:56 AM   #4
notsolo
notsolo's Avatar
I would pop the inspection cover off and check the bearing is sliding smoothly, fork is seated on the ball pivot. Fork is in the groove of the bearing. Bearing turns freely but doesn't spin like the grease is out of it. Also check transfer case shift action.
notsolo is offline   Reply With Quote
