Old 05-10-2016, 01:50 AM   #1
CastIron
CastIron's Avatar
Sway Bar Question
I recently acquired a 1 1/4" front sway bar (off of a late 70s 3/4 ton) for my '69 C1500. I got the mounting brackets with the bar and ordered some new Moog bushings (K6476) as per some the other sway bar threads.
I've got everything cleaned up and ready to install. Here's the problem: the bushings looks like they are about 1/4" too tall for the brackets. There was washers under the brackets when I took them off the donor truck, but they aren't close to being thick enough. I'm pretty sure if I tried installing them right now the bolts would be tight but there would be a gap between the brackets the the control arms/frame brackets. The original bushings were rubber and in pretty bad shape. It doesn't look like the urethane bushings are going to compress very much without causing the bar to bind. I'm thinking I'll have to add a few washers under each bracket. Anybody have any better ideas?
I've already looked at a lot of other threads and I've only seen one other person use washers under the brackets.
CastIron is offline   Reply With Quote
Old 05-10-2016, 03:39 AM   #2
Toms67
Toms67's Avatar
Re: Sway Bar Question
Any chance you could grind The bushings to the proper height? You could do a little at a time until you get what you need.
Toms67 is offline   Reply With Quote
Old 05-10-2016, 09:07 AM   #3
Rich69shortfleet
I've done this before. A lot depends on how much material you have at the flat part of the bushing to the hole for the bar. There is probably a lot there, just shave away a little on the flat section until you get the fit you want. Also, you want to leave the bushing a little tall so that it will be slightly compressed by the bracket to help hold it in place. Be sure to lube the inside of the bushing with the sticky snot grease that should have been supplied with your bushings. Do NOT use any kind of petroleum based grease.
Rich69shortfleet is offline   Reply With Quote
Old 05-10-2016, 11:06 AM   #4
midniteblues
midniteblues's Avatar
I have seen conduit clamps used in place of the oe/aftermarket clamps for one reason or another.
They look very similar.
My clamps look slightly different than yours.
These are well used moog 1 1/4" bushings and oe clamps for comparison.
These are well crushed and still show 1/8-3/16" difference.
I think these bushes are part#5061.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-11-2016, 12:05 AM   #5
CastIron
CastIron's Avatar
I ended up grinding off a little of the bushings and using washers under the clamps. It seems to work just fine. I used some rubber grease (designed for brake caliper pins) on the bushings.
I took for a test drive and there is a noticeable difference in how it handles. A lot less body roll on corners, and seems to be more controlled hitting bumps. I can't believe I waited 15 years to do this! Now I just need an overdrive transmission and some power disc brakes.
Here's a picture of the truck, because I know everybody like pictures.
Old 05-11-2016, 01:26 AM   #6
AKC
AKC's Avatar
I had to go look at the brackets from my donor with the K6476 bushings I have after seeing this post. Mine look fine. Whew! Don't do that!
My guess is your donor didn't have the correct brackets to begin with, they do look like conduit clamps. Might explain why the rubber bushings were trashed.
Glad you were able to make it work and are happy with the results. Nice lookin' ride...
'Anela - AKC's 1968 C30 1T Flattie
"Trouble Rides A Fast Horse..."
AKC is offline   Reply With Quote
Old 05-11-2016, 09:28 AM   #7
Rich69shortfleet
You will love disc brakes. When I put 71 discs and large rear drums on my 69 it was a completely different truck. It took towing from a scary proposition to a manageable experience. I only towed once or twice with the old drums, that convinced me to upgrade right away to discs.
I too would love to upgrade my TH350 to something with an overdrive.
