05-12-2016, 12:27 AM | #1 |
My defroster covers interior with moisture
Does anyone have an idea why this is happening? I don't smell antifreeze, can't find any leaks, and my windshield doesn't leak. Carpets are bone dry. Can't find any moisture in the cab. But when it rains, and I turn the heater/defrost on it covers the entire interior with moisture. Dash, windows, gauges. It is blowing hot and there is strong air coming from the defrost vents. If I don't turn on the heater at all it is not as bad. I also notice that when I wash the truck, I get small circles of moisture just above the defrost vents. I'm stumped. This truck was stored in a heated garage it's whole life, 17k original miles. It's like a time capsule. The rubber is all very soft, it was like buying a one or two year old truck. everything works like butter. Windows, cold air vents, door latches. This is the only thing that seems out of sorts.
"A man's got to know his limitations" 1969 Chevy C20 Camper Special 1968 Chevy C-10 short/fleet 1970 GMC Jimmy 4x4 (SOLD) |
05-12-2016, 06:30 AM | #2 |
Re: My defroster covers interior with moisture
Your heater core is shot. It leaks coolant into the heater box creating steamy air being blown. You are better off using your wing vents and a towel until you replace it
05-12-2016, 09:25 AM | #3 |
Yup what K says.
Saskatoon, Saskatchewan Canada |
05-12-2016, 10:01 AM | #4 |
Msgt USAF Ret
I don't think it's the heater core for four reasons.
1. He doesn't smell anti-freeze- I've had three vehicles with leaking heater cores and the smell is unmistakable. 2 He hasn't said anything about low coolant. 3. The carpets are not soaked. Mine were every time. 4. It only seems to happen after a wash or heavy rain. This sounds like a leak into the heater box maybe a drain hole is plugged, If he has AC there should be a drain for condensation in the lowest part of the system with a rubber drain tube to the outside, or the heater core box gasket isn't sealing.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
05-12-2016, 11:35 AM | #5 |
Bought the truck in Portland, OR three weeks ago. Drove it home to Brentwood, CA. (East edge of the S.F. Bay Area) So I've only had it for three weeks and put 1000 miles on it. Coolant seems to be staying put so far. It doesn't have AC. Plan to pour some water in the cowl vents today and check if it's draining properly.
Thanks for all the input so far.
05-12-2016, 12:33 PM | #6 |
Just an idea, but you might check the rubber grommet where the antenna coaxial cable goes through the cowl. I had a dried and cracked grommet that allowed water to seep down the cable and drip into the GM under-dash air conditioner unit. It also happened right after I washed the truck or when it was raining. I had condensation out the vents when the AC was turned on.
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
05-12-2016, 02:32 PM | #7 |
I had exactly that happen in my 1975 Pontiac Bonneville. I was driving home from college in 2001 and the defroster blew moisture onto the windshield.
I had to get a new heater core. I guess water could be getting into the system though from outside, like the guy said he had happen with his antenna grommet. Anyone else want to weigh in? I do know that to remove your heater core you'll have to have your hood off along with the passenger side hood hinge. Fortunately the heater box is easy to take apart and replace the core, I did that to mine. |
05-12-2016, 04:37 PM | #8 |
Im agreeing that its the heater core. I had simolar symptoms and it was a bad heater core.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
05-12-2016, 05:48 PM | #9 |
If it only happens after rain/outside water. Happens ,Not seein it being a heater core? Try riding around with heat/defrost on dry day for giggles?
05-12-2016, 09:53 PM | #10 |
Born Psycho
i've seen this truck in person and it is beautiful inside and out. my first thought was heater core too but it only happens when water is on the outside and like Larry stated-the coolant level isn't going down and the unmistakable coolant smell is not present. there has to be a small leak somewhere from the outside getting in. now, Larry, where are the pics so the rest of the board members can drool over this jewel.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-12-2016, 10:37 PM | #11 |
I responded without reading the info much at all. I thought I saw you could smell anti-freeze and stopped reading there, when I was already thinking heater core. I've seen them leak without getting the cab wet, though.
I'd guess it's a seal to your heater or that antenna seal
05-12-2016, 10:37 PM | #12 |
Is the coolant water, or a mix?
If it only happens when it rains maybe a leak between the body and the heater system? |
05-12-2016, 10:46 PM | #13 |
Sorry Jerry. I can't figure out how to edit my signature. How am I supposed to post pictures?
05-12-2016, 10:55 PM | #14 |
So I poured water in the cowl vent on both sides. It drains beautifully. It is a beautiful 80 deg today and sunny. I ran the defrost on high and it fogged all the windows but not to near the degree it did on the rainy day. All the windows fogged then the windshield started to defog above the defrost vents. Absent was the heavy moisture on the rest of the interior surfaces. The seal between the heater box/fan and firewall is soft and pliable and appears in really good shape. The weather strip between the cowl and hood is cracked and misshapen. I ordered a new one today. I'm busy working the rest of the night but tomorrow I will try pouring water across the front of the cowl while running the defroster on high. See if that replicates the symptoms. If not, I guess I can remove the cowl vent for the fist time in it's life ): I'll keep updating the progress. And maybe get Jerry to come over and show me how to post pictures. ._.
05-12-2016, 10:59 PM | #15 |
05-12-2016, 11:00 PM | #16 |
Son, of, a,..........hey, I got it (:
05-12-2016, 11:21 PM | #17 |
Holy mackerel, that thing is beautiful. Congrats for sure. Enjoy!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
05-12-2016, 11:28 PM | #18 |
Born Psycho
05-12-2016, 11:38 PM | #19 |
I was watching that one on eBay and drooling! Same color as my 69, but mine doesn't have the white top. I'm glad to see a forum member got it.
05-12-2016, 11:33 PM | #20 |
Looks like the garage couldn't keep the cab mounts from rotting a bit, regardless of mileage... but that's an easy fix!
See, now that you've posted photos, your defroster issue is forgotten, and we're all just going to look at your truck.
05-13-2016, 02:40 AM | #21 |
Nice rig !!! so cool you know all the history of her!
05-13-2016, 12:34 PM | #22 |
Thanks to all for the congats. The coolant is green and smells like a fresh mix of antifreeze. Oscar was anal about maintenance so I can only assume it was changed regularly. I am planning an oil change, coolant change, PS fluid change, and a trans service.
I know, some will cry "Sacrilege!" that I would change anything on such a low mileage truck, but I'm anal about being safe. My wife and kids will be riding in this truck. And considering the upgrades Oscar made I think he would make similar changes if he were still the caretaker of this rig. So.... Planned upgrades: Disc brakes, three point seatbelts, electric fans, fuel injection (FITech?), MSD electronic distributer, quick ratio steering box, poly cab mounts, and suspension rebuild. Probably LED bulbs for the brake lights and backup lights. And way down the road, when I recover some funds, maybe a Gear Venders overdrive. Or a 4L80E? Not sure. I will box and preserve all of the original parts for the future caretaker just in case he is one of those preservationist collectors. If I'm 92 when that day comes, this truck will be 84 years old. And I'm hoping to find a model of BedRug that fits in the bed. I had one of these in my 2002 Dodge Dakota and it is the only thing I've seen that will save the paint in the bed and allow you to use it like a truck. They only make them for late model trucks and they will not do custom. There has to be one that's close enough to make fit with maybe slight modifications by an upholsterer. Has anyone out there done the research?
05-13-2016, 03:09 PM | #23 |
BTW, Jerry, you were right as usual. The gear ratio is 3.54. Do you know what model dana that is? 60?
05-13-2016, 04:34 PM | #24 |
Sorry Spec-K, didn't read you question before my last post.
The rear bumper is chrome. The diamond plate on the step is painted silver. I don't think it's GM. It has a decal on it that says "Transport Supply Co." There are phone numbers for Berkley, Ca. and West Sacramento, Ca. Both are less than an hour drive from me, ironically. I plan to change it to a factory chrome bumper with a class IV hidden hitch. The spare looks to be original bias ply. There are still nubs on the tread and the size matches the build sheet. The wheel is silver. My guess is the broker had the wheels powder coated white and put new radials on. I can see some pitting on the edge of the rims under the paint. Does anyone know if the original wheels would have been silver? Jerry, the diff has a 10 bolt cover. Is that dana or eaton? I thought the Dana's had a 14 bolt cover. Box 17 on the build sheet is labeled "AXLE" and has the code "BJ". BTW, the build sheet, box 58-59 "WHEELS" has code "HR2" for both. Then "RP9 F950X165X8 N" and "RP9 R950X165X8 N" are listed in the options which I believe are the tire sizes. Does the 8 in there mean 8" wheels?
"A man's got to know his limitations" 1969 Chevy C20 Camper Special 1968 Chevy C-10 short/fleet 1970 GMC Jimmy 4x4 (SOLD) Last edited by larryboy_3t5; 05-13-2016 at 04:47 PM. |
05-13-2016, 06:38 PM | #25 |
If I were you, I would get a spare truck to haul stuff around in
