Does any company make a...
Does any company make a spare tire bracket for a long bed stepside? I want to put the spare on my truck, but can't find a used bracket and haven't found an aftermarket one. I don't have the wheel cutout, but my spare will fit easily between the fender and cab. This is the bracket I have seen others use for this...so hopefully someone can point me in the right direction. My truck was converted to 5 lug also, but I assume the bracket can be changed. Thanks!
![]() Join Date: Aug 2004
Re: Does any company make a...
I would look for someone near you fab it for you. Looks kinda easy to make imo.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I thought about that...I keep telling myself i want to learn how to weld. A member sent me a PM and said they may have one laying around...if that doesn't work, I will look into having one made. Thanks
Anyone else?
I've never seen one. I'd say go to harbor freight, buy a cheap flux welder and make one up with some nice steel bars. I think I just do that eventually
it would probably be easier to make a new 5 lug bracket than to find and modify a 6 lug bracket
all the rod supports aim for 6 lug points, a properly designed 5 lug bracket would be easy angle iron is all that you need to for the bracketry and a 10 ga plate for the lug pattern the oem bracket isn't that heavy, though it is triangulated to make it very rigid i didn't have a choice as mine is swb fender mount 6 to 5 adapter plate and spacer to mount the 255 spare, instead of the stock 5'' spare ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#7 | |
![]() ![]() Join Date: Apr 2012
Ive got an extra if needed
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Big Thanks to Jon--60-66 for finding me a spare tire hanger for the LWB stepside! This will be a great addition to the truck! Can't wait to get it...
