Old 05-20-2016, 11:34 AM   #1
pvienneau
pvienneau's Avatar
Drum Brake Booster under frame set up
Has anyone here done a booster to their original drum brake setup? I'd like to retain the 16" wheels and new tires and not do the 5 log change. Any help and suggestions are greatly appreciated.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 05-20-2016, 12:10 PM   #2
Lo1dakota
Lo1dakota's Avatar
Re: Drum Brake Booster under frame set up
Don't let 16 inch wheels keep you from doing a disc set up because you can run a disc set up in six lug behind those 16 inch wheels most likely. With any factory mount brake booster you were still going to have to modify or run new lines most likely it will be easier to run new lines. Check my build in the project section of this forum labeled Daisy
Lo1dakota is offline   Reply With Quote
Old 05-20-2016, 01:08 PM   #3
OrrieG
OrrieG's Avatar
stock tf and ad 16 wheels will not clear a lot of calipers. I had a 59 steel wheel that fit the back drum fine, rubbed on the front caliper (74 front 4wd axle). 16" steel wheels from 72 on will work, but not with stock TF hub caps. I used 68-72 dog dish caps, look old enough that most will not know they are not 59. You will need to replace the stock MC, I would find one with separate front and back reseviours. You will need a proportioning valve too. I'd replace the lines and hoses too, since they are 55+ years old.
Old 05-20-2016, 04:05 PM   #4
pvienneau
pvienneau's Avatar
I had everything ordered this AM from Speedway then found out it was only 5 lug. I canceled the brake parts but still ordered the power steering kit.
Pat
Old 05-20-2016, 04:09 PM   #5
pvienneau
pvienneau's Avatar
If anyone knows of a 6 lug disc brake that will work with my 16 inch rims please advise. I want to go disc up front and drum in rear but not at sacrificing the 16 inch original wheels.
Pat
Old 05-20-2016, 05:55 PM   #6
OrrieG
OrrieG's Avatar
In my opinion, good adjusted power drum brakes will work as well as discs in single panic situations and daily driving. I have them in my 64 Chevelle can stop just fine. Disc advantages are ease of repair/replacement and better cooling in constant braking situations.
Old 05-21-2016, 08:52 AM   #7
nvrdone
on my drum brake system, I used a disk brake booster & m/c under the floor. added a 10# check valve to the front line & every thing works good
nvrdone is offline   Reply With Quote
Old 05-21-2016, 09:43 AM   #8
1project2many
To answer the original question, I have a Hydrovac here that I plan to install in my truck. Hydrovac was available as a factory option for TF trucks.
http://dave78chieftain.com/HydroVac_brakes.html
1project2many is offline   Reply With Quote
Old 05-21-2016, 01:59 PM   #9
mr48chev
mr48chev's Avatar
Had a hard time figuring out what you wanted as in your first post you asked for a power master setup for drum brakes and later said you want disks that work with the stock wheel
Scroll down to Six lug complete brake kits about half way down the page.
http://www.classicperform.com/Chevy-Truck.htm#3
Not cheap but everyone else copies theirs.
My ongoing truck projects:
