05-22-2016, 08:34 PM | #1 |
U-joint intermediate steering shaft
Does anyone make a direct replacement steering shaft for our trucks using u-joints? I have found custom made applications but nothing as a direct fit. I've heard switching from the rag joint to a u-joint is a huge improvement.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
05-23-2016, 12:22 AM | #2 |
Re: U-joint intermediate steering shaft
You can use one off a jeep - if you search here, it will tell you models and years. Did it to mine. Nice improvement.
05-23-2016, 12:34 AM | #3 |
I did a search. Maybe just not hard enough. Was it a direct fit or did you have to modify?
05-23-2016, 07:37 AM | #4 |
If I remember right, Jeep Cherokee 1984-2001 and Borgeson makes a universal fit our trucks. It's a little more $$$.
Rick |
05-23-2016, 08:12 AM | #5 |
05-23-2016, 11:49 AM | #6 |
You will have to grove the upper part of the shaft where the bolt goes through. It's a little different there.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-23-2016, 05:39 PM | #7 |
Depends on the year - mine didn't need grooving.
05-23-2016, 05:46 PM | #8 |
There might be more tutorials out there, but this is a decent explanation. I don't think it gives the exact year/model of jeep to pull the intermediate shaft from, and I don't know off the top of my head, but I have seen that information here on this website so I know it exists.
https://www.youtube.com/watch?v=H9C4RdvjPNQ
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
05-24-2016, 12:42 AM | #9 |
Interested in this also
05-24-2016, 07:10 AM | #10 |
What's your thoughts about a collapsible vs solid shaft? The Boregson is and the Jeep is but I've seen some that are a solid DD. Would make a difference in a front end crash.
Rick |
05-24-2016, 10:43 AM | #11 |
05-24-2016, 11:31 AM | #12 |
I found it somewhere on line, but what I did for mine was take the jeep shaft, and burn out the plastic like suggested. I next welded a strip of metal along one side of the upper shaft. I drilled and tapped 3 holes in the strip. I put set screws into each hole. I tightened them up to take up any play, but not overly tight, and used red loc tite on them. This still should collapse and took care of the play.
