Old 05-22-2016, 08:35 PM   #1
GR8-68
GR8-68's Avatar
How wode can you go ?
Question is how big of a rear tire can you run before you have to widen the wheel wells ?
GR8-68 is offline   Reply With Quote
Old 05-22-2016, 08:38 PM   #2
BugzC10
BugzC10's Avatar
Re: How wode can you go ?
Step or Fleet Side?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 05-22-2016, 09:58 PM   #3
swamp rat
swamp rat's Avatar
1/2T or 3/4T?
Which rear end?
Leaf spring or coil spring..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-22-2016, 10:29 PM   #4
GR8-68
GR8-68's Avatar
1/2 ton fleetside
Old 05-22-2016, 10:34 PM   #5
Ram-Man
Ram-Man's Avatar
A couple other things are the early narrow housing or the wider later housing wheel offset will also factor in. I've got a deep offset 5.75 with a 50 which is about a 9.5" wide and have less than a 1/2" from rubbing on the inside when tucked and aired out.
Ram-Man is offline   Reply With Quote
Old 05-22-2016, 10:45 PM   #6
GR8-68
GR8-68's Avatar
I have the narrow housing, so I assume that probably would make it worse..
Old 05-23-2016, 07:59 AM   #7
Tiger Joe
I just went thru this.
The widest tire I could have fit without cutting anything was at 28x12x15. Only reason I didn't is because they didn't come in the style I wanted.
I ended up with a 275/55/15 on a 15x10 with 4.25 BS.
I have a 67, so mine is the narrower axle according to this site.
Tiger Joe is offline   Reply With Quote
Old 05-23-2016, 08:30 AM   #8
brihorse
Narrow axle only affects the backspacing of the rim. It won't affect tire size.
brihorse is offline   Reply With Quote
Old 05-23-2016, 08:32 AM   #9
c10ss69
c10ss69's Avatar
I'm running a 20x10 with 5.5" backspace. Tire size of 295/45-20 which is 30.45" tall. Total of 8" static drop on the rear and have no rubbing issues at all.
Mike
c10ss69 is offline   Reply With Quote
Old 05-23-2016, 09:42 AM   #10
DBK81
DBK81's Avatar
This is all irrelevant information as it will be dependent upon what rim you run (offset/back spacing) if you want to know the width you have to work with go measure from inside your rear tub, from side to side and you will have your number, from there it's a matter of finding the right wheel to maximize that space, you can go into 300 series tires with the right back spacing.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 05-23-2016, 10:46 AM   #11
GR8-68
GR8-68's Avatar
That sounds like a reasonable explanation. But i do not have the truck assembled
