05-24-2016, 02:05 PM | #1 |
Porterbuilt Big Block chevy
Anyone running the Porterbuilt with a big block Chevy Mark IV engine?
I have a Porterbuilt level 3 ordered and I just had a 496 big block built for it but I have never seen a big block with porterbuilt. any input on how the fit is? It must fit, the big block was a option when ordering
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
05-24-2016, 09:44 PM | #2 |
Re: Porterbuilt Big Block chevy
I've done a 502 ramjet install with a pb dm that came with the truck, not impressed with there customer service.
05-24-2016, 11:39 PM | #3 |
Did you happen to have to notch your oil pan to clear the rack steering?...I saw one that had to. There is VERY little on Big block DM
05-25-2016, 02:01 AM | #4 |
No I lowered the rack which will help with the bump steer ( the more you keep your rack parallel the better for this) My main goal is to get the truck to handle so i lowered the motor so the pan is 3/4 " above the dm. and I moved the engine back 1 1/4.
06-05-2016, 06:13 AM | #5 |
I'm running a level 3 dropmember with a 396, the rack and pan are close but with the motor/trans dropping back at 5 degrees for the driveshafts it brings it up and off the rack, although not by much.
06-05-2016, 10:43 AM | #6 |
Great to know. I'm about ready to set my motor. I seems not a lot of people put Big Blocks with the Porterbuilds. What Headers did you use?
06-07-2016, 10:48 PM | #7 |
what headers are those?....any photo of the oil pan clearance to the rack steering
07-10-2016, 10:54 PM | #8 |
lowered rack 1 1/2"
11-03-2016, 10:04 AM | #9 |
Did you have to make clearance for your valve covers against the firewall?..Photos?
