05-29-2016, 09:22 PM | #1 |
WTB Flexplate
I am in need of a flexplate *(flywheel) for 66 250. switching to automatic transmission
Thanks, joe |
05-29-2016, 10:04 PM | #2 |
But Found Her 25yrs Later!
Re: WTB Flexplate
When I was looking for a flexplate, I learned there were two different sizes.
So you may want to specify which size you want. You'll want the same size as your manual flywheel if you are going to use same starter. (14"=168 teeth--12 3/4" = 153 teeth.)
05-30-2016, 06:51 PM | #3 |
Re: WTB Flexplate
Good to know.
Thank You |
05-30-2016, 11:17 PM | #4 |
60-66 Nut
Re: WTB Flexplate
You will not be able to use the same starter when changing from a manual trans to an automatic. The manual trans starter bolts to the bellhousing and with an automatic, the starter bolts to the block.
