Where do I find used Gear Vendor over/under?
Ok so I know eBay has them sometimes, but I've heard from more than one old timer that Gear Vendor over/under drives can be found on motor homes. What I'm hoping somebody will know, is if there are certain year/make/model motor homes these came on? OR, were these guys I talked to who mentioned it referring to just any old motor home that somebody has installed a gear vendor on, which would make my search much harder and probably more expensive.
This isn't a hurry up and get it done type of thing, it's more of a side project that I'm tinkering with while I have the truck up on jackstands doing the brakes/suspension work. Any leads are appreciated or comments/ideas about doing a project like this, always welcome. The truck is a 1970 C10 LWB, 355/th400 with 3.73 mini spool, one peice driveshaft, 2wheel drive hot rod/fun truck that will be SO awesome with a gear vendor! ![]() |
![]() Join Date: Dec 2013
Re: Where do I find used Gear Vendor over/under?
Have you considered a 4L80e may be cheaper in th e long run .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
A few years back I was really into the idea and actively searching for the correct one (although mine would need to go behind my sm465) and I called a guy I saw selling them (I think it was on Craigslist). He was out of Sacramento or close to it, very knowledgeable and honest, because with my lack of knowledge in regards to the ratios he could have sold me one pretty easily. But instead he shot my idea down! ;-0 He said I would hardly notice a difference due to the fact I'm running 3.07's.
I'll check my notes and see if I have a phone number but keep an eye on CL for someone that has more than one for sale, at the time he had like 4 or 5 listed.
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
There's a few by me and close to you, one for a 400. I can look for you Wednesday if you contact him. Not mine
http://chico.craigslist.org/pts/5562400650.html |
You can use any one you find and then buy the right adapter for your transmission from Gear Vendors. I don't think they came stock on any vehicles. You would gain something on any vehicle because they add 22 % to the final gear ratio but also can be shifted manually to add 22% to your other gears. They put them on the Calloway Corvette and I think it had 273 gears.
69 Chevy 4x4 383 Power ![]() |
#7 | |
I have mine on my SM465/NP205/4.10 equipped Blazer with 35" tires. Makes driving the Blazer soooo nice on the freeway. An overdrive will not benefit really low gears because it will bring the rpms down too low to be in the engines power band while cruising, and the engine will bog down under load.
Yes it mounts to the output of the 205 mine is on a 208
Now that you say that, I vaguely recall that is what the guy I spoke with was telling me. Basically he said not worth it.
#11 | |
Check your rpm at cruise speeds next time you're out driving. Just because you won't be in the engines power band while driving on the freeway or anytime your in overdrive for that matter, doesn't mean you won't like it. Heck who wants to be in the power while cruising anyway? If you need power downshift lol |
#12 | |
![]() ![]() Join Date: Sep 2008
https://saginaw.craigslist.org/pts/5561585095.html
#13 | |
You guys that do these with all new parts, how much is it costing you after its all said and done?
#15 |
I found mine at a swap meet, it came out of a 454 SS truck.
#16 |
I've seen these pictures of your truck before, that setup with the long adapter just looks bulletproof
#17 |
I've done some reading on the amount of horsepower and torque soaked up by the th350 and th400 transmissions, but I couldn't find anything about the Gear Vendor and if/how much additional power they soak up. Seems like the loss in the transmissions is due to rotating mass, but a gear vendor is relatively small correct? Depending on the adapter?
I've seen the inside of a gear vendor and it's a lot like a transmission, but what's inside the adapter? Just a driveshaft inside the adapter housing? Thanks guys for all the replies |
#18 |
![]() Join Date: May 2010
Here are 2 for TH400s in Phoenix. Second one is never installed.
http://phoenix.craigslist.org/evl/pts/5614793002.html http://phoenix.craigslist.org/wvl/pts/5572663321.html |
#19 | |
#20 |
If you end up buying one near Phoenix, I'll be down there for a week around the 15th and could pick it up for you if it will save you shipping. I'm sure it won't be cheap.
#21 | |
Matt |
#22 |
If i was to get a Od gear again I would never use a gear vendors. I had to take my perfectly balanced drive shaft and use plumbing hose clamps to get the driveline vibiration under control. I have dumped thousands into getting it nearly smooth. Now the solenoid is being called "lazy" and GV wants $150 plus shipping for a replacement. Getting parts is difficult and expensive here in Canada
The cool factory didnt last long with it not working properly. Especially when spending $3000+++ on it I am far from impressed I had advice not to use a gear vendors from a older gentleman that owned a transmission shop. He said why do you want a second transmission to worry about maintaining ? his advise was to use a 4l80
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 06-02-2016 at 11:37 PM. |
#23 |
on the first one? the box on the right? looks like he has it laying sideways and thats the oil pan.
#24 |
There are 2 different cases that the gear vendors can be purchased with. There is a standard one, and one with a larger sump for extra fluid capacity. The one with the larger sump is recommended for RV'S and tow vehicles.
#25 |
Ok so the guy said on the used one he bought a truck with a 502 that has a rod knocking and he's parting it out, and he will pull the wiring/switches out with it. If I remember correctly there is some kind of junction box or relay that I'll need with it right? He said he will pay shipping if I use PayPal, which is fine with me if he's offering, I just want to make sure I'm not going to need a 3-400 dollar wiring harness and relay kit from gear vendor on top of the 1000 bucks he's asking. He never drove the truck but said these units are indestructible so he's sure it works, kinda makes me nervous but it sounds like he's bein honest
