Old 05-31-2016, 12:44 PM   #1
1968ChevyC30
Resistor wire on a 68?
Having spent several hours scratching my head over why my new MSD #8360 "ready to run" distributor and MSD #8202 coil won't operate properly with my freshly built 327. I have spoken with MSD Tech as well as gone over the wiring diagrams, and remain baffled as to why this distributor won't work. As a test, I installed a used Accel electronic distributor without a ballast resistor using the MSD #8202 coil and all worked fine. I also went so far as to obtain another new MSD #8360 distributor only to have the same problem as with the first one. MSD states that a ballast resistor isn't used with their setup, yet the Accel unit requires one. This leads me to believe there is a resistor wire within the engine harness that I can't find within the diagrams I have. Can any of you offer any assistance with my dilema? Thanks in advance.
1968ChevyC30 is offline   Reply With Quote
Old 05-31-2016, 01:12 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Resistor wire on a 68?
If it was not previously converted correctly to HEI, the wire from the bulkhead connector to the coil is a resistor wire. It can be taken out of service and a new wire run to the ignition unfused terminal (if I recall correctly) inside the cab or replaced at your discretion.
This thread should help. The "good part" starts at post 11.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
Another:
http://67-72chevytrucks.com/vboard/s...d.php?t=553330
FirstOwner69 is offline   Reply With Quote
Old 05-31-2016, 01:28 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The resistor wire on the stock truck from the factory is located in the firewall block by the master cylinder. it was an orange white purple originally but has probably faded over time to just a whitish cloth wire.
a Looking at the MSD website diagram The ignition wire from the key switch goes directly to the coil Positive terminal, so they don't show a resistor or wire in the circuit.
I would try running a 12 gauge wire from the IGN UNFUSED terminal on the fuse panel, directly to the coil positive, and try that.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-01-2016, 10:26 PM   #4
quick60
quick60's Avatar
I'm not sure about the photo. You have two wires identified by 1 and 2. But the resistor wire in question i am assuming by your description is the wire with the woven jacket on it?
quick60 is offline   Reply With Quote
Old 06-01-2016, 10:27 PM   #5
quick60
quick60's Avatar
Also does anyone have any suggestions on resealing the back of the wiring harness block once you install the new wire?
Old 06-01-2016, 10:58 PM   #6
CastIron
CastIron's Avatar
On my 69, the woven wire is the resistor and runs down to the starter. Then it goes back up the coil as a regular wire. I don't remember the color, red or yellow? But I removed both wires when I installed a new HEI distributor and replaced it with a 12 gauge wire coming from the same spot on the bulkhead connector and going straight to the coil. I rewrapped the harness and it looks like it could be factory now.
CastIron is offline   Reply With Quote
Old 06-01-2016, 11:21 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
You could either pack it with non-conductive silicone grease, or use silicone RTV. Just remember to scrape any RTV off the contact surfaces after it dries.
I know the factory used some brown, waxy, sticky, smelly stuff back in the day. It was probably Bear Fat. Can't get it now due to environmentalism.
Old 06-01-2016, 11:08 PM   #8
'68OrangeSunshine
The 20 Or/Wht/Ppl is the woven line in VV's above pic. [Its not numbered since the pic if from another discussion. It would be #3, maybe.] This line terminates with a split to two 20 Yellow wires, behind the block; one to the Starter and the other to the stock Coii (+) terminal. The 2 yellow wires are also redundant in electronic operations, and should be taped off, at least.
Old 06-02-2016, 12:41 PM   #9
1968ChevyC30
Thank you for all of your responses. I ultimately wound up running a 12 gauge line from the unfused ignition lug on the fuse panel inside the cab directly to the coil and it resolved my issue with the MSD ignition system. Now that the engine is broken in and running, I can now concentrate on finishing the truck and posting photos of the net result of this complete body off full restoration with a few minor mods. Again, thank you all for your assistance. I'm very pleased to have found this forum and the generosity of the information willingly offered.
