Anyone used Mcgaughys disc brake kit with stock drum spindles?
So the front drums on Gold Digger are completely shot
![]() Heres Gold Digger btw ![]() |
Re: Anyone used Mcgaughys disc brake kit with stock drum spindles?
I'm watching this. I too am looking for the most economical way to put discs on the front of. Y truck
Try looking for scarebird classic brakes. I have used them on my 65 mustang. Will use again when I build my 69 chevy c10. http://scarebird.com/index.php?route...product_id=150
Last edited by Onelefttoget; 06-01-2016 at 01:19 AM. Reason: Found helping Web page |
#4 | |
![]() Join Date: Jun 2009
Understand that this kit only comes with brackets and does not include the rotor an caliper
I am converting mine to the 72 model spindle by just using 72 ball joints I bought a whole front end from a junk yard for 125.00
#7 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
You will need it because the tie rods are different and centerlinks aren't reproduced.
#8 | |
Posted via Mobile Device |
#9 | |
QUOTE: Kit includes 6-lug rotors. Fits models with only heavy duty stock brake rotors measuring 1.25 in. thick. Must be used with McGaughy's spindle numbers 63173, and 63174.
Also you must switch the M/C to a disc brake version and add a proportioning valve for disc brakes.
So im looking at their site and i see these to convert the back to disc brakes also. Does anyone know if these are the right pattern for the 12 bolt in my truck? Like was there a difference between the car and truck 12 bolt rearend axel tube flanges? https://scarebird.com/index.php?rout...product_id=146
![]() Join Date: Feb 2016
That Mcgaughys kit is no where near to getting you on the road.
Beside the kit you'll need to buy spindles, swap master cylinders, get a proportioning valve, and a pair of front wheels that will clear the discs. I'd say try to find a 73-87 front frame cut from a truck being parted out, do the suspension swap under your truck, use the entire brake lines and all from master cylinder all the way out. Then buy a pair of 6 lug rotors from ECE or CPP or wherever you choose would come out cheaper. |
