06-03-2016, 10:48 PM | #1 |
Small block Fuel pumps??
Is the only difference's in fuel pumps being the bottom inlet & outlet lines Orientation setups in which way they are pointing & is the threaded outlet all the same size. I am having a tuff time in finding a line setup that will work with my 1989 305 ci eng. from a Pont. Firebird. Most to all Catalogs only go up to 87/88 for trucks not cars. I know I am going to have to do some modification to the line closest to the carb ( its a Holley) thats a given there. any help or direction would be great, thanks.
My truck is a 68 C10 lwb coils all around |
06-04-2016, 10:04 AM | #2 |
Re: Small block Fuel pumps??
Not quite sure what you're wanting, but the fuel pump specific to your '68 with a SBC should work, unless you have altered the tank and lines. Newer pumps had 3 ports ( for emissions). As long as the cam in your '89 305 has a fuel pump lobe, factory pump for a '68 small block should work fine.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
06-04-2016, 12:31 PM | #3 | |
06-04-2016, 10:16 AM | #4 |
I'm also not sure what you need but I just got this pump from Summit. The bottom is clockable so you can orient the in/out ports.
http://www.summitracing.com/parts/sum-250020-1b
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
06-04-2016, 11:57 AM | #5 | |
06-04-2016, 02:24 PM | #6 |
Ok I think I get it. On my '67 the fuel line is 5/16" . on '80s sbc the fuel line was 3/8" . Are the fittings the same size for both????? I do not know,but if you can get that info , you should be able to buy the correct fuel line/or make one!!!
06-04-2016, 04:34 PM | #7 |
So I guess if I buy a fuel pump for a let say a 68 w/307 or 327 eng's and then I should be able to get a stock hard line for the 68 setup? I know at the carb the hard line will need to be modified for my Holley carb.
06-05-2016, 02:31 AM | #8 |
Yes
06-05-2016, 05:15 AM | #9 |
06-04-2016, 07:32 PM | #10 | ||
"I ain't nobody, dork."
I bent my own 3/8" steel fuel lines from my mechanical pump to Holley carb.
Gary
