Old 06-04-2016, 10:44 AM   #1
IronX
stabilizer bar install from a 80's check to a 71
Hello all, I am installing a front stabilizer bar from a 86 3/4 ton chevy to my 71 custom 10 1/2 ton chevy. The question I had is do I need to jack up the frame so the a - arms come down to pit it on or put it on while it's sitting on a level surfce. I have to drill the holes to put the hold downs on it too. Any advice would really help. Thanks in advance.
IronX
IronX is offline   Reply With Quote
Old 06-04-2016, 11:12 AM   #2
roboticjunky
Re: stabilizer bar install from a 80's check to a 71
On a level surface, on the ground or have your truck on ramps.
roboticjunky is offline   Reply With Quote
Old 06-04-2016, 11:23 AM   #3
Redline novdog
Redline novdog's Avatar
i had enough room under mine (factory ride height) to install while sitting at normal ride height, no ramps or jack required.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 06-04-2016, 01:32 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
You will love the difference in handling with the sway bar installed.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-04-2016, 02:07 PM   #5
Redline novdog
Yes you will actually enjoy on/off ramps ! LOL!
Old 06-05-2016, 12:48 AM   #6
IronX
So I just drill new holes for the sway bar u - clamps and neoprene bushings? 2 on the front and 1 set on each lower a-arm. Has anyone ever done one like this? Tho ones on like I see have that long bolt holding it on each lower a-arm and I have that big flat U-band holder with neoprene bushings. Thanks guys I really appreciate all the input!
IronX
Old 06-05-2016, 02:16 AM   #7
CastIron
CastIron's Avatar
Here's an old thread with lots of good pictures and information:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
CastIron is offline   Reply With Quote
Old 06-05-2016, 10:30 AM   #8
IronX
Thanks cast iron I appreciate it! Have a nice day
Old 06-05-2016, 01:31 PM   #9
davischevy
davischevy's Avatar
You shouldn't have to drill any holes.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
