Old 06-04-2016, 10:22 PM   #1
reed62
reed62's Avatar
Impala steering column swap?
Has anyone done this? The columns look similar. Just wondering if anyone has done anything other than the usual 73-87 swap or aftermarket piece.
reed62 is offline   Reply With Quote
Old 06-04-2016, 10:48 PM   #2
notsolo
notsolo's Avatar
Re: Impala steering column swap?
I have done similar swap years ago. I think the column 's are very close, but the mounting point...2 bolts up thru are in a different location. You need to drill out the rivet holding the reinforcing plate. Move it to new location, then drill new holes. May not be needed if your looking for more room behind the wheel.
notsolo is offline   Reply With Quote
Old 06-04-2016, 10:50 PM   #3
reed62
reed62's Avatar
Thanks for the response. I found a salvage yard with dozens of 65-67 Impalas, as well as an auction for a 65 column with tilt.
Old 06-04-2016, 11:56 PM   #4
DPowers
One foot in front of the other
DPowers's Avatar
I put a '64 Impala tilt in mine.
http://67-72chevytrucks.com/vboard/s...64&postcount=8
DPowers is offline   Reply With Quote
