06-05-2016, 03:42 PM | #1 |
oil pressure stumps me
Ok i have a 69 c10 350 5.7 4bbl i put new breather new oil fill cap pcv valve working great.. since i put new breather and oil fill cap my oil pressure gadge maxes out during acceleration any ideas what my problem could be
06-05-2016, 03:50 PM | #2 |
Re: oil pressure stumps me
Those things should not effect the oil pressure. Did you change oil at the same time? Your old oil may have been thinned out or you may be using a thicker grade of oil. Does it come down after it warms up? You need to put a master gauge on it & see how high it is really going. 50-60 lbs is OK. If it goes up to 100 or more you have a stuck relief valve.
06-05-2016, 04:00 PM | #3 |
Ok thanks for the input i will check it out... what grade of oil do you recommend....
06-05-2016, 04:10 PM | #4 |
The relief valve your taking about is it the one where the oil filter goes
06-05-2016, 05:07 PM | #5 |
The relief valve where you screw on the oil filter is to bypass the filter when the engine is cold. The relief valve is in the oil pump itself. Like Wrenchbender said, stick a mechanical gauge on that has numbered graduation on it and see what the pressure really is.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD 1970 Chevy Nova - Street and Strip Project 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
06-05-2016, 07:55 PM | #6 |
use the correct filter, not just one that fisically fits. some pressure relief valves are in the filter and some are in the pump. They can fight each other and give the erradic pressure indications you decribe.
but mor information might be nessessarry is pressur erradic when the oil is cold, is it erradic only on accelaration what is oil pressure when warmed up and idleing. what is pressure warmed up and at cruis. |
