Old 06-05-2016, 10:57 PM   #1
Rich69shortfleet
LEDs all around on my 69 C10
This weekend I installed a new gauge cluster adding a factory tach and vacuum gauge and a new engine harness to clean up the engine compartment and tidy up the wiring to the HEI. I also installed LED park lights, side markers and tail lights. The tails are from Digi-Tail and have a sequential setting. Everything went in well and everything worked without much fuss but there was a bit of cursing here and there. I also found time to install park light LEDs in the wagon and the seat belts that finally showed up into the old GTO. A VERY good weekend all around. Only real problem was that the new printed circuit for the gauge cluster had an exposed bit of circuit on the back side and shorted out against the housing. I was able to fix it, but I really shouldn't have to mess with a brand new part like that. Going to call tomorrow about getting a replacement.
Here are the LEDs in action:
http://www.youtube.com/watch?v=Qn_ar...ature=youtu.be
Rich69shortfleet is offline   Reply With Quote
Old 06-06-2016, 12:34 AM   #2
Jayred
Re: LEDs all around on my 69 C10
Your truck is bad ass-- from the flat paint, to the wheels, to the stance. It's old school/kinda rat rod. LED's kinda suck. I'm not trying to be a jerk bc your truck is awesome, but the knight rider stuff needs to go...
Jayred is offline   Reply With Quote
Old 06-06-2016, 01:35 AM   #3
Foureye71
Foureye71's Avatar
Im diggin those led's. I would eventually like to do the same for my 71'
'71 K1500 Short-Wide
Foureye71 is offline   Reply With Quote
Old 06-06-2016, 08:18 AM   #4
Rich69shortfleet
Yeah, well, I don't really like the flat paint rat rod look at all and that is the next thing to go. Shiny paint and a fresh interior will be a great leap forward along with a wood bed and polished stainless bed strips and bolts. The patina, such as it is, is only there because I haven't yet gotten around to doing anything about it yet, it certainly isn't intentional. About half the paint is original and very, very tired.
Old 06-06-2016, 08:59 AM   #5
n33k0
Neat. Did you have any trouble with the flashers and getting the turn signals to work?
I've been on the fence about getting LED marker lights and brake lights. I don't want to see the individual spots of light from each LED bulb, I would rather just have one "bar" of light rather than a row of separate dots. Is it possible to separate the lens from the bulbs so I could install some sort of diffuser to blend the LED lights together?
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 06-06-2016, 09:06 AM   #6
Rich69shortfleet
The only trouble I had with the turnsignals was easily fixed. Everything flashed with the emergency flashers but the turnsignals didn't flash. I read in another thread that you sometimes need to reverse the connections on the flasher so I tried that with a couple of short wires and the turnsignals then flashed properly.
The park lights and side markers I bought were sealed units, no way to get inside and do anything different. The tail lights had to be assembled and are a separate circuit board you mount inside the housing, though the LEDs are pretty close to the lens when it is all together so I don't think there is much room to put any kind of a diffuser lens between the two.
Old 06-06-2016, 08:59 PM   #7
Mrturner1
Nice 4th post. Sometimes it's better to just keep your mouth shut, especially when you can't help but let dumb crap fall out.
Awesome truck! LED's are lookin good
Mrturner1 is offline   Reply With Quote
Old 06-06-2016, 08:09 PM   #8
firedemon
nice I want to do the led conversion on mine anything to brighten it up so people don't pile into the back of me . this is new York people here cant drive and don't care first thing they tell the cop I didn't see him
firedemon is offline   Reply With Quote
Old 06-06-2016, 10:16 PM   #9
Wide Open
Looks nice!
I see you mention the brand of taillights but unless I missed it I didn't see which side marker lights you used.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 06-07-2016, 08:40 AM   #10
Rich69shortfleet
Originally Posted by Wide Open View Post
Looks nice!
Front park lights and side marker lights are made by United Pacific. They are the ones all the big truck parts sellers (LMC, Brothers, etc.) sell. Nice units.
Getting the front side markers wired so they would provide (dim) running lights AND (bright) flashes with both the emergency flashers and turnsignals was a whole lot more trouble than it should have been. Wiring the rear sides was easy. GM really wired the front side markers in a weird way, but hey, bulbs only have OFF and ON not OFF, DIM, BRIGHT. But still, the ground in the front side marker bulb sockets are also apparently switched which was what through me at first. Seems that is how they got the front sides to blink with the emergency flashers.
Old 06-07-2016, 02:43 PM   #11
Rich69shortfleet
threw me at first
(sure wish the edit feature was available for a bit longer)
Old 06-07-2016, 04:01 PM   #12
Custom 68
Custom 68's Avatar
Those look great. Led lights are always a great upgrade and I like those.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 06-14-2016, 10:31 AM   #13
Rich69shortfleet
I added LED bulbs in the back up lights and they too look great. Those "bulbs" came from Digi-Tails too. I added 1156 LEDs to the courtesy lights in the interior, super bright! I also added an LED to the dome light but it is not as bright as the incandescent it replaced but provides adequate light and the courtesy lights make up for it. I like the idea of having a dome bulb that won't melt the housing or lens if the doors are open for an extended period. These LEDS all are Sylvannia and came from the local parts store.
Old 06-14-2016, 11:36 AM   #14
Wide Open
Cool. Good info to know.
