![]() Join Date: Apr 2015
1972 c10 ring and pinion swap.
Hey guys. Probably been asked 1000 times but here's 1001.
I have a 72 lwb c10 with a sb 400 and th350 trans. Putting out 530 hp at the flywheel. I have 3.08 rear gears right now. What would be a good gear swap. I was thinking 3.73. Maybe 3.42. Any suggestions??
72 C10 sb 400 530hp 71 C30 dually sb 327 70 Pontiac Tempest GT 37 sbc 350 |
Re: 1972 c10 ring and pinion swap.
I currently have a 72 with the 373 gears. about 5% of the time they are great for hauling. the other 95% of the time I wish I had an overdrive gear.
I dont suppose youl be hauling fire wood, cinderblocks or old cars with it. you will be greatfull for the better milage and the current(?) or future use of an overdrive with a 342 gear set up. Your 308 differential "case" is compatible with any gear ratio bellow 373, so to choose a 342 ring and pinion will save a bit of money there, but 373 diff cases are quite common too and ought not to cost much either. tough call . I like my 373 gears but sure wish It was more hiway friendly that 95% of the time. |
#3 | |
![]() Join Date: Jul 2010
Here is a great gear ratio chart you can use to help you decide. You can play around with different scenarios.
http://www.grimmjeeper.com/gears.html
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
#5 | |
I had a BBC 67 Camaro with 308 gears.a bit sluggish on acceleration. I think the 342's would be a good bet.
Yea I think it's he best bet. Won't have to change carriers either. My posi unit is in good shape.
I just put a 3.08 in my 68 about 3 weeks ago , it had a 3.73 this is a DD and travels the interstate everyday the SB 350/th400 with 3.73 combo hated the interstate above 65 mph .
So I put 3.08 in and now I can push the truck with ease to 100 mph did not really feel that much different still pull up hills the same and still Lites the tires up from dead stop till she shifts in to 3d . |
Tags |
1972, 3.08, 3.73, pinion, ring |
