![]() Join Date: Jan 2012
2 New Tires, Coker BF Goodrich, 285 /70R15, Radial, 3.50 in. Wide Whitewall with powder coated chevy rally wheels.
No shipping at this time, i have them listed locally on CL as well. New tires these cost $287.00 each and $40.00 a wheel for powder coating you get them for $450.00 Brand:Coker Tire Product Line:Coker BFGoodrich Silvertown Radial Tires Tire Size: 285/70-15 Wheel Diameter: 15 in. Sidewall Style: Whitewall Tire Construction: Radial Tire Diameter: 30.75 in. Tire Diameter Range: 30-30.99 in. Section Width: 11.50 in. Tread Width: 8.60 in. Minimum Recommended Wheel Width: 7.50 in. Maximum Recommended Wheel Width: 9.50 in. Directional: No Asymmetrical Tread Pattern: No UTQG Tread Wear Rating: 320 Tread Depth: 12/32 in. DOT-Approved: Yes Tube Required: No Max Load Single (lbs): 2,679 Notes: 3.500 in. whitewall width. These BFGoodrich Silvertown radials from Coker Tire are great for classics, hot rods, and customs. Available in classic whitewall and redline styles, these tires are S speed rated and are DOT and ECE-approved. Silvertown radials feature a high-tech, all-season tread design and are great for big and little combos. Tires with 13 to 16 in. rim diameters are available. They're the perfect tires for your cruising car! |
