Old 06-16-2016, 09:32 PM   #1
Mrturner1
How to get new looking bright headlights on a '70 c10?
Hey guys I was wondering how to make the headlights on my C 10 nice and bright like a new car or truck? Is it just a matter of changing the headlights or do you have to put a stronger charging system in and do a bunch of wiring?
Mrturner1 is offline   Reply With Quote
Old 06-16-2016, 09:40 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: How to get new looking bright headlights on a '70 c10?
there is a headlight post on here about putting a relay in so you can get power right from the battery when your headlights are on
69chevytrucker is offline   Reply With Quote
Old 06-16-2016, 10:30 PM   #3
davepl
davepl's Avatar
You'll need a relay setup, but the biggest change comes when you switch away from sealed beams to a proper lamp+reflector setup (which is what new cars use).
I converted my truck to run H7 HID lamps. So that's two steps - you could stop at the modern lamp (like an H7) or continue to replace the lamps with HID modules, which is what I did.
They're not quite this blue in person, they just photograph that way.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-17-2016, 08:41 PM   #4
Overdriven
What are the headlight housings you're using? H7 is just a bulb would like to know what is holding it in your truck. I've seen a thread about using Jeep JK housings it it said they were H11. So I'm curious if you're using something different (more options is always good) or of that bulb info was wrong.
Overdriven is offline   Reply With Quote
Old 06-17-2016, 09:36 PM   #5
davepl
davepl's Avatar
LMC sells buckets that accept the lamps:
36-0281 CUSTOM HEADLIGHT-7” CHEVY 67-68 (2) 43.69 34.95
36-0290 HALOGEN REPLACEMENT BULB WHITE (2) 8.69 6.95
Those are Chevy, they also have the 4-lamp GMC setup. I can't swear they're H7, they could be some other lamp style, it's been a couple of years.
Old 06-18-2016, 12:12 AM   #6
Overdriven
The bulbs aren't a big deal, I was just using it to try and figure out what housings/buckets you have. Either way thanks for the info on them, like I said always good to have more options.
Old 06-18-2016, 02:00 PM   #7
davepl
davepl's Avatar
OK.... you got the part where 36-0281 is the bucket, right? Don't mean to be pedantic, but I wasn't clear about it.
Old 06-16-2016, 11:55 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
As said above, do the relay mod for sure. Also make sure all grounds are clean & tight, so that extra voltage can be put to good use. No other wiring or charging system upgrades needed.
Many different options available when it comes to replacement headlamps. Some better than others, and prices all over the map. I'd avoid the cheap stuff but that just my opinion. The only replacements that I have experience with are H4 E-codes. Of those, Hellas are cheaper and easier to find, but Cibies have a better light pattern esp. on high beam. Best price on Cibies that I have found so far is on Amazon. Read a few reviews there, most rate them highly. Their pic looks slightly yellowed but it's crystal clear glass.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-17-2016, 08:16 AM   #9
Mike C
Mike C's Avatar
I did not do the relay mod on my '69 but I did do the Hella H4 conversion headlights and they work great. Excellent mod for about $80 from Amazon. My local 4 Wheel Parts stocks them as well.
You can get a pair of Halogen headlights at the auto parts store for less than $20 which will help, but as mentioned above, re-do our grounds and clean all the plug in connections well. That include at the horn relay and the high/low floor switch.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-17-2016, 09:58 AM   #10
Mrturner1
Any particular relay setup? Or just a relay in general? I think I'd like to go a step further like yours Dave, HID's look great
Old 06-17-2016, 10:28 AM   #11
rx78nt1alex
rx78nt1alex's Avatar
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=293913
1968 Chevrolet Fleetside C-10
1971 Chevrolet Fleetside C-10
rx78nt1alex is offline   Reply With Quote
Old 06-17-2016, 12:00 PM   #12
PeterHall
We're planning on doing HID/projectors.
PeterHall is offline   Reply With Quote
Old 06-17-2016, 12:00 PM   #13
davepl
davepl's Avatar
Just avoid the LMC "headlight upgrade harness" that comes with relays and a big yellow cable. A bunch of them have been wired wrong internally and I had to fix mine by removing all the wires and starting over, basically... high and low beam backwards, etc.
Old 06-17-2016, 08:51 PM   #14
joeydurango
joeydurango's Avatar
I did the relay mod and used Sylvania Silverstar sealed beams on my last K10, and that made a world of difference. On my current truck I've just swapped in Silverstars, haven't yet done the relay mod - better, but needs the relays.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 06-19-2016, 12:49 AM   #15
prodjay10
Already Gone, would you be able to send us the instructions?
prodjay10 is offline   Reply With Quote
Old 06-19-2016, 01:30 AM   #16
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I couldn't find anything in my files but found this thread from 2006 with the instructions and if my old fuzzy memory is good I think this is the thread I used to do my relay wiring. I remember going to a wrecker and getting the relays from a scrap Dodge Minivan.
http://67-72chevytrucks.com/vboard/s...d.php?t=182351
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
