Old 06-17-2016, 11:45 AM   #1
Motasupra
1953 lm7 5.3 suspension questions
Hi we just got a 1953 5 window back into the family after about 10 years. Found the same truck but now engine and transmission are shot. So instead of rebuilding we have a lm7 and a 4l60e we're going to toss in. I have seen a lot oh threads about v8 swaps but not so much lsx motor swaps that are completely done. I need some pics of what you did to clear the steering? Also we're on the fence about ifs or upgraded I beam with disk brakes. Thanks
Motasupra is offline   Reply With Quote
Old 06-17-2016, 02:16 PM   #2
torchlight
torchlight's Avatar
Re: 1953 lm7 5.3 suspension questions
We made it work with a single connecting shaft, but to accomplish this we used custom-built headers that have the exhaust for the #1 cylinder "bumped out" somewhat to provide clearance for the steering shaft to go through. This bump out also required modification of the inner fender to create a "hump" that allows the headers to fit without making contact. Used an ididit retrofit column and an 88 t-bird rack as part of a Scotts Hot Rods IFS setup (mustang ii basically).
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 06-17-2016, 04:15 PM   #3
Motasupra
Wow that's a good looking set up. Thanks for the pics as well.
Has anyone done this with I beam ? We looked at the speed way I beam with disks but just don't know if it will make things worse or not. Also we do want power steering with either set up and 4 wheel disk.
Old 06-17-2016, 10:50 PM   #4
tmoble
the best I-beam truck I've driven was much worse than the worst IFS one I've driven. The IFS on that one was the Mopar passenger car setup and was very poorly installed to boot. Any kind of a Mustang II or Pinto setup will drive better.
BTW, the I-beam truck I mentioned was my own, all rebuilt by me with much care and all new parts including springs. Tried many things to get it drive well, but it was still a buggy spring setup at best.
Disclosure: my truck now has 2nd Gen Camaro front and C4 Vette rear, drives like a go-kart, only with suspension.
tmoble is offline   Reply With Quote
Old 06-17-2016, 11:38 PM   #5
mongocanfly
mongocanfly's Avatar
Check into flatouts crossmember and a vette front..that's what's going in mine..light weight, power rack, 12"disc brakes...http://www.flatout-engineering.com/products.html
Old 06-22-2016, 09:16 AM   #6
solidaxel
solidaxel's Avatar
Your truck will much more fun and driveable if you change the front suspension to IFS
and power steering
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-23-2016, 10:55 AM   #7
Motasupra
The way the truck sits now the front bumper sits 13" off the ground and the rear of the running boards is 10". It's lower in the rear mini gasser style. What is the ride height of the ifs? We don't want a super low truck but we would like it to be safe at speed. Possible test and tune nights at local car show kind of thing but the focus is daily driver not a drag car. We have a drag car and it's no fun on the street plus 110 octane in Cali is not cheap to put in just to go for a cruise.
Also is this one of the better sites to use for a 53 build? Seems to be a lot of people on it and good information on the forum. Thanks
Old 06-23-2016, 11:21 AM   #8
solidaxel
solidaxel's Avatar
City, highway, some off road mine work great.
Measure the bumpers in the parking lot and go for 1 inch clearance as a starting point for your front bumper
I think I measured the front of my running boards at 7 inches
LS 3 4L70E
Old 06-23-2016, 12:57 PM   #9
mongocanfly
Solid is spot on with about 7"..most are driveable at around 6" with minor scraping here and there..7 will be a little cushion..on mine 6 is what I'm going for..that's where they look best to me if your not using balloons for suspension.. (sorry..couldn't resist)..
Old 06-25-2016, 03:26 PM   #10
BlueJeep
BlueJeep's Avatar
Mine is 5.5" at the front of the running boards. 3000 miles driven last week and zero scraping, though I did get it stuck on the beach in Louisiana.
Mine's on an s10 frame, all the details are in my build thread but I averaged 22mpg with the 5.3.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-25-2016, 08:46 PM   #11
Motasupra
Thanks for the information. I'm looking at all the build threads and I think I'm learning a lot.
This is what it looks like today with the front higher then the back. Is there a way to have ifs but have it ride a little closer to stock.
[IMG][/IMG]
Old 06-25-2016, 08:52 PM   #12
Motasupra
We rolled a front runner off our car up to the truck for fun. We will be taking the truck to the strip from time to time. We need a new driver fender.
