10-01-2003, 10:23 AM | #1 |
MY TRUCK IS FOR SALE!!
Here is a question for you..
When I bought my truck it had a coat of primer on it in some places and a coat of primer over paint in other places..
My question is, how far down do I sand it off to? Bare metal? In some places in my truck you can see discoloration, looks like the rust color is going through the primer. What I want to do is sand everything down and put a new coat of primer and eventually paint it... I am just not sure on how much to sand off... Please help, thanks
1979 Chevy LWB 350ci / 700R4 Edelbrock under the hood F O R S A L E OR T R A D E |
10-01-2003, 10:55 AM | #2 |
The original paints/primers adhere & seal quite well so the discoloration within the new primer could be rust forming. Not all primers are equal in quality. Someone might have sanded through the original to the bare metal then just applied some cheap stuff which absorbs moisture & allows rust to form.
If you cant do all @ once, fix the spots where the rust is forming. Strip them down, re-prime w/some quality primer, & then seal them w/some paint that won't absorb moisture.
10-01-2003, 12:24 PM | #3 |
Hey is it not a good idea to use primer from a spray can?
Should I go and try and find a air compressor and use a paint gun, which I do not have. Also, I should probably try and find an electric sander, instead of doing it by hand..... right?
10-01-2003, 01:02 PM | #4 |
91 SWB 383
lol. what me answer again . lmao . just plaing
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
10-01-2003, 01:22 PM | #5 | |
www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-01-2003, 01:25 PM | #6 |
91 SWB 383
u go to alot of the froum i go to . that cool . that one way to get the right info . lol
10-01-2003, 01:44 PM | #7 |
My opinions of primer and paint:
The only way to do a proper primer and paint is to strip whatever is on the metal surface all the way down to the metal. Once you're at the metal you can see where the rust is (check both sides of the metal suface if possible) and deal with it accordingly (rust through will require surgery, or just remove superficial rust). You may find it very difficult to strip the paint/rust with just sand paper, or maybe you'll find you're using a lot of sandpaper. Stripping paint with wire brushes attached to drills also worked well for me, it scraches the metal up a bit but a good primer coat covers that. Once the paint is removed, you clean the metal, wet sand with 500 or so, then dry thoroughly with acetone or something, then apply a nice primer, sure you can use primer out of a spray can, just make sure you do the proper number of even coats. If you're talking about doing your whole car then you might want to think twice about the spray can idea. After the primer sets, you've got to wet sand that down to a nice even surface and then apply the paint. Then you're done! easy enough. |
10-01-2003, 02:30 PM | #8 |
HEY KEVIN!!!
You read me like a book!!!
LMFAO!!
10-01-2003, 02:32 PM | #9 | |
"easier said then done"
