Thoughts on cleaning the fuse block
I am trying to clean up the original fuse block. The wiring is in good shape but the fuse holder a a little rusted. Any thoughts or suggestions on cleaning the fuse holders.
Thanks for the help
KippnIdaho Twin Lakes, Idaho 1966 K10 SWB Stepside 2003 Jeep Rubicon 2011 Camaro SS Rag Top |
Re: Thoughts on cleaning the fuse block
Maybe some emery cloth? Or fine sandpaper.
![]() Join Date: Feb 2016
Q-tips and valve grinding compound. The q-tip stems are kinda weak and fold up with a little bit of pressure but it gets in the curves and works. I then used a 99 cent store spray bottle with some rubbing alcohol and an old tooth brush to spray and brush the grime away. Disconnect your battery first to be safe.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
I've wondered about using the wire brushes from a 22 cal. gun cleaning kit?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Thanks for the thoughts and ideas.
I do have the block out do to the fact that I am doing a frame off. I am currently in the process of putting back together, frame and running gear all back together. So I am trying to do the little things like the fuse block now. Thanks again for the info, this place is great.
60-66 Nut
You might try those little sanding boards the women use on their nails. Might have to trim them down a little to a usable size.
some good ol' emery cloth should work pretty well.
If you are going that far as a frame off (nice by the way) I would just rewire the whole tk. American auto wire has new stock wiring kits (you probably know this) I used the non stock one for 60-66 tks, just more fuses but uses stock plug ins. (you have to make the wire ends though) I tried to use a driemel with a wire wheel, but mine was to rusty. didn't help much.
1961 chevy K10 my build is------------61K10 build |
