Old 10-01-2003, 06:31 PM   #1
~72'Pete~
~72'Pete~'s Avatar
My seat only locks on the drivers side
and is loose on the passenger side, its a adjustable bench in a 72 c-10.............my stepdad said im missing a pin?
Where can I get this part?
~72'Pete~ is offline   Reply With Quote
Old 10-01-2003, 06:40 PM   #2
neonlarry
neonlarry's Avatar
Its more than likely that the wire that runs across to that pin under the seat is bent not allowing the pin to engage. Just look under the seat and see where that wire runs from the seat latch to the other side and you will see where it engages the right side rail. It doesn't take much for that not to engage.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-01-2003, 07:21 PM   #3
Ironhorse
Ironhorse's Avatar
If you do find you are missing the latch piece let me know I have one from an old set of seat brackets I am not needing. You can have it for FREEEEE!!!!!! It is about 3 inches long, has several notches cut in it and is about 1/4 " thick. Let me know if it is what you need. Fits into the seat bracket and hooks one seat bracket to the other seat bracket through the use of a wire.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-02-2003, 12:04 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you stuff junk under your seat, then it is REAL easy to bend the wire that controls the pin.
If you can't figure it out by looking under the seat, pull the seat out (8 1/2 inch bolts) and flip it on its back. It is a very simple design.
Old 10-02-2003, 03:22 AM   #5
71-longbed
Its Magically Delicious
71-longbed's Avatar
on the passenger side there is also a spring and tab that keep the tooth shaped metal peice in place.... mine was missing this ... it would pop loose only when i had a passenger ..then there side of the seat would "float" back and forth while i was driving ...strange sensation .... i got the tab and spring at a boneyard for nothing
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
