Old 10-01-2003, 07:53 PM   #1
smbrouss70
smbrouss70's Avatar
New Member w/ a few questions
Hi, I'm new here and have read quite a few of the threads and I have a few questions that haven't been answered.
First of all, I read somewhere that ECE's 6" drop rear coil doesn't need to have a c-notch installed, if I were to put those coils on my 70 Chevy and add the c-notch with a 2" block, would it cause a problem?
Secondly, does anyone have a good idea about getting rid of the gas tank behind the seat, without having a tank hanging below the rear bumper? I would like to be able to put at least a 20-25 Gal. tank and keep it hidden almost completely.
And Lastly, I've seen on a few websites, especially when they use airbags, that people have cut off the steering stop and the whole bump stop mount in order to gain clearance. Does anyone know if this will cause any steering problems as far as steering too far to one side, and if not will that help me get a tighter turning radius?
Thanks for your help, in advance!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 10-02-2003, 05:30 PM   #2
SCOTI
SCOTI's Avatar
If they say you can use the 6" w/o the c-section, it should work w/the 2" blocks & a c-section because you'll gain an extra 2.5" of travel when using c-sections.
You can use a stock blazer tank, an aftermarket tank from NoLimit, or one of the board members here (FuelCellGuy) posted he could build them to your specs.
Your turning radius will be limited by the internal stops in the steering box & the amount of back spacing your front wheels have. The more b.space, the sooner they interfere w/the lower a-arms
Hope this helps.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-03-2003, 12:28 AM   #3
smbrouss70
smbrouss70's Avatar
Thanks, that's exactly the info I was looking for. I appreciate it
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
