Old 06-25-2016, 02:52 PM   #1
chrismoore701
chrismoore701's Avatar
79 turbo 350 lockdown cable adjustment
I have searched YouTube with no luck. How do I adjust the kickdown cable. When I open it up the cable will slide forward but will not return. Is that correct?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 06-25-2016, 04:07 PM   #2
69heavychevy
69heavychevy's Avatar
Re: 79 turbo 350 lockdown cable adjustment
Interested in this as well. From what I understand you adjust it to where the throttle pulls the cable at WOT...or close to it.
And yes the cable should spring back. I've tried adjusting mine but I can't seem to notice a difference...
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 06-25-2016, 06:04 PM   #3
SkinnyG
SkinnyG's Avatar
That's the detent cable.
There's a square sort of clippy thing in the plastic right behind the bracket at the intake manifold. Pull it up so it "unclips" the cable.
With the detent cable unclipped, push the throttle to WIDE OPEN. Holding the throttle wide open, push the square clippy thing back in so it locks the cable at that adjustment.
Boom. You're done.
There will be some slack such that the detent cable does not even move until somewhere close to half throttle. That's normal.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 06-26-2016, 09:06 AM   #4
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: 79 turbo 350 lockdown cable adjustment
Skinny G is dead on 100%
it can help if you have someone hold the gas pedal wide open so you can use 2 hands on the clip. just make sure the throttle actually is wide open
TrailerTrash is offline   Reply With Quote
Old 06-26-2016, 11:35 AM   #5
chrismoore701
So I tried to lift that metal tab on the cable and it bent a little. How do I get it up to adjust? Tried to pry with screwdriver. Well that didn't work
Chris
Old 06-26-2016, 11:56 AM   #6
geezer#99
geezer#99's Avatar
Put that screwdriver away!! LOL!!
Two kinds of them.
Older style you push the tab up from the bottom.
Newer style you push the tab in from the top.
Search youtube for vids. Lots there.
Old 06-26-2016, 12:09 PM   #7
chrismoore701
Figured it out. Thanks guys. Now just need to go for a test drive. I have owned this truck for 26 years and never knew how to do that. Pretty embarrassed.
Chris
