Bolt pattern change advice 6 to 5
For the back story, my dad bought a 54 Chevrolet 3100 back in the mid 60s. I have owned it since the late 70s. I finally got to the point in life that I tore it down for some major refurbishment. He also at that time put a set of vintage E-T torquethrust wheels on it using 6 bolt to 5 bolt adapter plates. I know they are not correct to the truck but they are all I have ever known it to have so they are correct to me.
I always hated the adapter plates. They resulted in bad suspension geometry and I always thought they were unsafe as they had screw in studs that tended to work their way out over time. Part of the upgrade was to do 5 bolt "the right way". The fronts were easy. Car front drums from the same year. The rears not as easy. Moser Engineering said they could weld and re-drill the flanges for the new bolt pattern. That is until I sent the axles to them. As it turns out, time is no friend as when they weld up the flanges, they are too hard to re-drill. They cannot make new axles as the bearing surface is too large for their equipment. They say someone with an end mill may be able to do it. I am no machinist so I don't fully understand the obstacles. What their suggestion is is to cut the rear end housing ends off and weld on later ends to get a different size bearing and the bolt in style axles vs. the C clip retained design. At that point, they could make me a set of axles to fit. Essentially, the $90 drill job just turned into a $700+ ordeal. I foresee problems with backing plates, brake design change, e-brake cable issues, and more, Has anyone gone through this or have advice/suggestions? I want to retain the torque tube design as it is a hydra-matic truck so a later rear end as a whole is out of the question I think. Is there a set of axles that would be the correct length and spline to work with the old rear end components with the new axle ends and the 5 bolt wheel pattern? That could save the custom axle part of the project. Looking for advice or past experience. Thanks, G.H. |
Hollister Road Co.
Re: Bolt pattern change advice 6 to 5
try http://www.strangeengineering.net/ or https://www.markwilliams.com/
I think they are sending you the long way round to fix the issue. Its easier for them but not for you |
I'd think that possible the problem isn't their equipment's capacity but what available axle blanks They have.
Another one to try might be Dutchmans motor sports. http://www.dutchmanaxles.com/c-clip-axle-pair.html On the other hand a 54 Chevrolet Car takes the same rear wheel bearing as a 54 Chevrolet 3100 truck. I don't know if the axle shafts are close to the same but it is worth checking out. I did some research and the differential carrier gaskets are different so swapping the axle housings won't work.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 06-28-2016 at 12:26 AM. |
![]() ![]() Join Date: Nov 2008
Why not swap out rearends? Am I missing something?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Hollister Road Co.
I'd have to believe that he wants to keep the closed driveshaft and matching trans.
It would be a lot simpler to go to a 5 on 4-3/4 open drive rear axle and transmission of choice. That is a reasonably easy one day swap. At least it was when I was 27 in 1973. Now that I am 69 it would take a lot longer. I think that the problem with having custom axles made is that most of them are set up for CNC operation and the blanks come in certain set
Cool beans, let us know how it comes out and what was done to get it changed over.
