Old 07-01-2016, 12:12 PM   #1
cysko9
MI '69
cysko9's Avatar
Ignition Switch Grounds
I'm putting in a push button ignition/start setup in my 73 K5 and am trying to figure out what to do with the 2 grounds that go into the original ignition switch. My new switch setup doesn't have grounds so I wasn't sure what the purpose of those was...
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline   Reply With Quote
Old 07-01-2016, 12:28 PM   #2
cysko9
MI '69
cysko9's Avatar
Re: Ignition Switch Grounds
By the way, here's a picture of my switch schematic. Any feedback would be helpful. I was also wondering where I need to tie the fuse block power in to this. Other than the 2 grounds, this the only wire unaccounted for...
1973 K5 Blazer
Old 07-06-2016, 11:50 AM   #3
68Timber
I know the pieces fit
68Timber's Avatar
I haven't had to take a column apart that far yet but member Gregski detailed how the switch works when he replaced his in his build thread "Restoring Rusty": LINK Lots of pics there too showing how it works.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-06-2016, 12:24 PM   #4
cysko9
MI '69
cysko9's Avatar
Thanks, I used his build a bit for reference. After digging around a bit under the dash it looks like someone has some some surgery and I'm missing some wires here and there. I was able to make it all work though (except for the cluster light s but that's probably just a fuse). I ended up just going with switches for acc and run plus push button to start. Seems to work well enough... I've kept the harness intact though incase I ever want to fix the actuator rod and use the ignition switch in the future.
1973 K5 Blazer
