07-03-2016, 05:39 PM | #1 |
Sealant on cylinder head bolts??
I have a 2002 S10 , 2.2vin 4.
I'm installing a new head,and the Haynes manual says to use sealer on the head bolts I normally use Permatex Aviation sealer,when needed. I know they're TTY bolts. Is this correct,as far as using sealer ? Also , the auto parts guy said to orient the split in the locating dowels away from the waterjacket.. Never heard of this.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
07-05-2016, 02:00 AM | #2 |
Re: Sealant on cylinder head bolts??
Ok,...talkedto Gm rep,and Fel-Pro rep.
Both said NO oil,and NO sealer.Head is torqued, so on to the rest.
