Will 6 lug disc brakes of 73-87 4 x 4 work on 69 conversion
Can I use the rotors off a 4 x 4 front end to go on a 2 wheel drive crossmember from a 73 - 87 truck to maintain the 6 lugs?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
Not Dusti,just Bob
I would not think so.4x4 uses totaly different suspention on the front than the 2-wheel drive,4x4 use leaf springs on the front and the 2 wheel drive uses coil springs and a-arms,I'am sure something just would not fit correct,maybe some body with more experiance has more info on it.
Bob W
72 cheyenne super 1/2ton 89 camaro |
i wouldnt see why the rotors wouldnt work, since thats what you were asking. not sure if they go on the same way or not. never had my 87 apart
S-C |
Not Dusti,just Bob
I looked in my chevrolet pickup parts interchange manual 1967-1978.
There were no interchanges for 4x4 to 4x2. I would think that the center of the rotor would be larger on a 4x4 for the locking hubs? I have read a few post about people wanting to keep 6-lug and have disc brakes but don't recall anybody having that sugestion. Plus that would be way too easy if you could just swap a few parts and keep 6-lug and get disc rotors ![]() Try it and let us know,I would like to put disc brakes on my wifes truck and be able to keep the wheels that are on it without buying a kit for big$$.
its all about the +6 inches
The 2 wheel drive has the bearings and races in the rotor while every 4X4 I have ever worked on (which, admitedly is a very small number) had a 'hat' style rotor that slid over the hub assembly.
![]() Join Date: Aug 2002
conversion
4x4 will not fit 2wd. spindles rotors are completly different. sorry to be the bearer of bad news
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE |
