Drum type pop from exhaust
So I just put in a new MSD pro billet HEI and I fired the truck up and it runs kindof rough and has this sound from the exhaust like somebody hitting a drum about once one or two times per second. What is that? It's not really a pop, but it's definetly coming from the exhaust.
Re: Drum type pop from exhaust
I put the distributor back in exactly like I took the old one out. Should I just start from scratch and pull the distributor and set it up at TDC?
sounds like the timing is off it runs so cant be that bad try turning distributor somewhere between 4 and 10 deg before with no vac to the advance
Check the firing order. Just to be sure, I've seen experienced mechanics get wires crossed.
How is it running other than the sound? Is the distributer the only thing you changed? Last edited by garyd1961; 07-04-2016 at 09:19 PM. |
![]() Join Date: Dec 2013
Is it a drumming noise or a knocking noise ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Just a pop kinda noise, I think I dropped the distributor in a notch or two off again. I don't get how I do that except that the oil pump drive slot gets turned a bit when I take out the old distributor. I always put it right back, and I thought it wouldn't drop all the way if it was off.
Pair of plug wires reversed? Check them.
Off by one? Does significantly advancing or retarding improve it?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
