Old 07-05-2016, 03:10 PM   #1
tdangle
tdangle's Avatar
Wood Bed Floor
When I started fixing up my truck, my idea was to remove the bed liner and replace the wood floor with something that looked really nice and use stainless steel strips in lieu of the painted ones.
Now I'm not sure what to do. The truck will never be show quality. I want it to look nice and still use it as a truck. This weekend I picked up a load of landscape rock. This would have killed a nice bed floor. Starting to think about just replacing the floor and painting it like the factory did or maybe just some sort of sealer and leaving the wood raw. It is always garaged.
What are you guys doing for the floor if you are still using it as a truck.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-05-2016, 03:19 PM   #2
Nooner
Nooner's Avatar
Re: Wood Bed Floor
http://www.tractorsupply.com/tsc/pro...t?cm_vc=-10005
Nooner is offline   Reply With Quote
Old 07-05-2016, 03:47 PM   #3
scooterpimp
scooterpimp's Avatar
Re: Wood Bed Floor
Was thinking of experimenting with composit decking for bed floors. ? Cuts ok & wont rot , sturdy.
scooterpimp is offline   Reply With Quote
Old 07-05-2016, 04:58 PM   #4
dennislbrooks
dennislbrooks's Avatar
Re: Wood Bed Floor
I know on the 42 the wood needed to be finished 3/4" thick. I am guessing a 67-72 is the same. Do they make the composite in 3/4" thick? it may be. Stock would be yellow pine with a coat of black paint on it. I think it is a thin spray coat both sides as the grain is still visible. Anyone know?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-05-2016, 06:24 PM   #5
1968aj
Re: Wood Bed Floor
I just replaced mine this weekend. I did it as cheap as I could. I got 8 treated 1x6 and stain and sealer from lowes. bought bolts from Fastenal. got strips off ebay. its not factory correct but looks better than the rotten boards I had. one pece of advice-----DO NOT DO IT WITH BED ON TRUCK---WAY HARDER
1968aj is offline   Reply With Quote
Old 07-05-2016, 08:21 PM   #6
jayoldschool
Moderator
Re: Wood Bed Floor
Compostite deck boards are too thick. However, the fascia boards are perfect, and that's what I used on my 65. Stuff cuts like butter, and the truck sits outside all year and it still looks perfect.
jayoldschool is offline   Reply With Quote
Old 07-06-2016, 10:35 AM   #7
Lou Boffa
Lou Boffa's Avatar
Re: Wood Bed Floor
Here's mine. Done w Trex decking. Used the original wood boards' profile, milled them with a table saw and used new strips. Bullet proof--even in the Texas sun.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 07-06-2016, 12:43 PM   #8
tdangle
tdangle's Avatar
Re: Wood Bed Floor
Some good ideas. I am going to look into the Trex deck boards and if I need to get a load of dirt/rock, I'll just put a pad down over it.
Terry
Old 07-06-2016, 06:39 PM   #9
In The Ten Ring
Re: Wood Bed Floor
I love the seamlessly welded 1/8" thick bed my dad made himself but if I was going to do it, I'd do with teak or what Lou did. I really like his recessed tie downs.
In The Ten Ring is offline   Reply With Quote
Old 07-06-2016, 09:07 PM   #10
Metaldoc
Metaldoc's Avatar
Re: Wood Bed Floor
Where are those tie down hooks from?
Metaldoc is offline   Reply With Quote
Old 07-06-2016, 05:14 PM   #11
GRX
GRX's Avatar
Went with Oak in mine. I hit it with steel wool and a fresh coat of one step Poly/Stain every other spring. Being that I often haul in my bed, and the truck spends majority of time outside, was not sure how composite would stand up to that. Given how yours will be mostly garage kept and probably won't do much hauling, composite may be your best bet.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 07-06-2016, 08:04 PM   #12
Greekdog
Re: Wood Bed Floor
are their directions or a thread showing how to mill the boards?
I think i want to give it a try but I dont know what the measurements and what not should be
Greekdog is offline   Reply With Quote
Old 07-06-2016, 08:12 PM   #13
Leonard60
Re: Wood Bed Floor
I found pics and complete instructions at GMCpauls dot com for all the measurements etc hope that helps.
Leonard60 is offline   Reply With Quote
Old 07-06-2016, 09:06 PM   #14
Greekdog
Smile Re: Wood Bed Floor
awsome man, thanks for the tip
