Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-09-2016, 05:20 PM   #1
Backpayne
WTB: Rebuildable 250 head
I am wanting to hop-up my current 250 by doing some headwork. I've never done any engine work like this and want to learn by doing. My current 250 non-integrated head is fine, but don't want the truck to be down.
Anyone have one they can sell?
Thanks!
Jeff
Backpayne is offline   Reply With Quote
Old 07-09-2016, 06:56 PM   #2
tkeduk8r
tkeduk8r's Avatar
Re: WTB: Rebuildable 250 head
I have a good one here.... but shipping could be an issue... 1.72 intakes 1.50 exhausts..... I did the lump port and oversize valves on one but haven't fired engine yet.... I have capability to machine head's and do rest of work.... 80 hours in to it!!!
Mike....
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 07-09-2016, 07:18 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I have a 250 head casting number 3895052 72.38CC
1965-70 on a 230
1967-72 on a 250
You can have it for $25.00, definatly needs cleaning/rebuilding.
http://www.inliners.org/tech/heads/headindex.htm
Old 07-09-2016, 07:36 PM   #4
Backpayne
1965-70 on a 230
1967-72 on a 250
I believe my 250 is from mid to upper 70s. Would that mean your heads would not fit?
Old 07-09-2016, 07:47 PM   #5
Backpayne
Crud, you're in Canada. Shipping would suck.
Tkeduk8, sounds awesome! Probably way out of my price range.
Old 07-09-2016, 07:51 PM   #6
aerotruk63
aerotruk63's Avatar
I put a 67 194 head on a 75 250 block and it worked. Not enough experience to be sure.
On my head we cut out the pillar between the intake ports and now use allen key flat head bolts to torque the head. This is part of the process to Siamese the ports. We put larger Valves in it as well. We ported the head to match the aluminum intake. So long ago I can't remember all the details. My buddy supplied me with articles on how to soup up a inline 6 and we followed as much as we could back in 86. We cut 1/4" off a Small Block Nascar Harmonic Balancer to fit on the Inline 6.
This is what it sounds like through two International Harvester resonators.
https://www.youtube.com/watch?v=5JKgJN7t0FI
Old 07-09-2016, 07:52 PM   #7
aerotruk63
aerotruk63's Avatar
I'll ship in New York State to help you out.
Old 07-09-2016, 08:24 PM   #8
Backpayne
How much? Shipping would be to 65745?
Is the rust just surface rust?
Old 07-09-2016, 09:28 PM   #9
aerotruk63
aerotruk63's Avatar
I would say you would have to have the head planed. Hot tank the rest. Will you oversize the valves? I could lighten it by removing the valves and springs?
Old 07-10-2016, 12:40 AM   #10
Backpayne
I would like to change the valves to 1.84/1.6 if I can do that myself (trying to read as much as I can, love learning to diy). I've also read that it milling the head down to 0.060 helps compression?
Once all this is done I'm going to upgrade the cam.
Old 07-10-2016, 02:58 PM   #11
jdl71
jdl71's Avatar
I have a spare 230. I'd sell the whole thing or just the head if you are interested. As far as I know, the 194-230-250-292 non integral heads are interchangeable but the 194's have smaller combustion chambers. I will also be in Branson next month for the car show and can bring it with.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 07-10-2016, 05:22 PM   #12
tkeduk8r
tkeduk8r's Avatar
Haha.... I meant I had 80 hours into the one I built, and I have a spare stock one here I'd let go.... but looks like you have someone who could meet you in MO to save on shipping.... on a side note the one I built for my 250 has 1.94 intakes,1.60 exhausts installed with new guides, Tom Lowe's lump port kit, intake bolt bosses removed, all ports ported/polished, and .120 milled off... combustion chambers cc'd out to 72 cc's.... you can remove intake bolt bosses yourself as well as he lump port kit and port and polish, however, unless you have a milling machine and some specialized tooling, sent the head out for surfacing and valve enlargement and hardened valves eats if needed... good luck!
Mike
Old 07-12-2016, 12:28 PM   #13
Backpayne
Man, you could probably get more money selling the whole engine on Craigslist.
Old 07-12-2016, 07:58 PM   #14
jdl71
jdl71's Avatar
It's not hurting anything where it's at. I was just offering to try to help a fellow member out. If you want just the head I'll be glad to pull it off for you, if you want to look elsewhere that's fine too.
Psalm 23
64 C10
66 K20
Old 07-23-2016, 05:44 PM   #15
Backpayne
Whoa! Forgot to reply!
I am very interested. When exactly will you be in Branson and how much for the head?
Thank you!
Old 07-23-2016, 09:30 PM   #16
jdl71
jdl71's Avatar
Idk, $75? I haven't taken it off yet, but it was a running engine with decent compression. The cam/crank gears broke a tooth or two off and it jumped time, so I pulled the engine and put another one I had in. I'll be there August 11-14.
Psalm 23
64 C10
66 K20
Old 07-25-2016, 11:15 PM   #17
Backpayne
Well crud. I won't be able to make it to Branson then. If plans change I will definitely let you know!
Old 07-26-2016, 09:07 PM   #18
jdl71
jdl71's Avatar
Looks like you are about 3 hours from here if you want to make the full trip sometime. We do go to Branson/Springfield several times a year so if you're not in a hurry...
Psalm 23
64 C10
66 K20
