Heater\Air duct box help
I bought the AC parts (in boxes) from a guy to put in my non-ac cab 72 c10. When I go to connect the outer Heater box that mounts under the dash to the Air Duct selector box, it does not match up very well. Is there some kind of narrow spacer that goes between the two that I am missing or should the two just bolt together?
Re: Heater\Air duct box help
Go here-
http://www.lmctruck.com/chevrolet/ They have a breakdown on how all the parts go together once you find the correct area.Look at heater parts. Mike. ![]() |
Thanks for the quick response & information. I live in KC area and know LMC all to well
![]() Join Date: Dec 2013
Post pictures when asking questions it makes it ten times faster to get good information ☺
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Old member
See if this helps. This is both parts outside and inside no other parts needed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Andy436, I have that same PDF document. If you look at “HEATER AND AIR CONDITIONING 1A-32”. “Fig. 39—Heater and Ducts” it has another breakout and appears to show a thin square piece that goes between the “heater core and distributor assembly” and the Air Duct selector box (which in the picture diagram you provided is labeled as “to right of dash outlet”, “To left of dash outlet” and “to center dash outlet” It with where the two items join together.
If I align the holes together for them to “bolt up” then the opening does not match up exactly. Grumpy Old Man- I tried to provide some pic’s but get this error message every time I try to upload pictures:Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error. I have sent several requests to the administrator with no response and same result every time I try to upload pictures. I understand a picture is worth a 1,000 words but no luck with uploading. I appreciate all the help and assistance. Not sure if something goes between them like it appears in the 72 PDF document called HEATER AND AIR CONDITIONING 1A-32”. “Fig. 39—Heater and Ducts” or not. |
![]() Join Date: Feb 2009
Literally, you're attaching the air duct to the heater box:
Duct Air Selector - Box 3: Mounting the Duct Air Selector Mount the unit to the Heater Box using two 5/16" head tapered screws. The annex portion of the unit inserts into the metal bracket fixed on the Heater Box. Cable Routing The cable for Box 3 was seated below the cable for Box 1. Not much else to this when mounted. Mounting the Cable See Box 1 for attaching the wire to the lever. Only difference is when the unit is in a mounting position, the cable should be positioned below the plate on the unit for mounting the cable bracket (i.e., the wire wraps clockwise). A/C Compressor Clutch Switch (button): The switch mounts to Box 3 using two 5/16" head tapered screws. This triggers the A/C when the lever pushes the switch button, where the A/C heater control is set to COLD. Tee Adaptor. The adaptor fits on top of Box 3. The duct tube faces the LH (TS). Nothing else to it on my 71. By chance your heater box isn't right?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Apr 2017
Reviving a fairly old thread, I have a couple questions. First of all, my truck is clearly a factory air-conditioned truck, but I have no center vent outlet for the air-conditioning in the middle of the dash. I do, however have the two side vents. What gives? Is that normal?
Secondly, does the duct flow selector box amount to anything other than the heater box? Seems like everything is just floating under my dash.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
Your truck should have the center vent with factory A/C. dash may have been replaced or cab was replaced or fake spid.
If you remove the inner / outer boxes you can tell if the A/C was added. Different holes than heater only. You can also look on the inside the dash for repair welds. The inner box is supported in the center with a screw though the fire wall just above the center heater outlet. Have some pics at work, will post later. |
Just replaced heater core. It’s definitely factory AC, based on the firewall.
That would be great!
Here's a pic: (I have a 1/4" bolt stuck in the hole just to mock it up)
Thanks!
Junior Member
![]() Join Date: Oct 2017
Hear are pictures of the differences of a 69 non ac cab firewall, Red, and a 72 Ocre a/c cab firewall.
Greg 69 Longhorn 396, 4 Speed SM 465, PS, PB, No Air |
