Old 07-20-2016, 12:07 PM   #1
SuperCtruck
SuperCtruck's Avatar
Upper Radiator Hose and water neck??
Any pictures of the upper radiator hose for a Chevy 283? I'm trying to stay as stock looking as possible!!
The upper radiator inlet is on driver side, so my problem is I have to purchase either a center water neck or one that face towards the driver side. My other issue is I'm looking at maybe purchasing the metal tube and coupling kit for my upper hose?!! Please let me know what you guys have done to make it work and look CLEAN! Thanks
I will be using a fan and radiator shroud
1949 Chevrolet 5 window
1970 C10 CST swb, fleet side
1964 C10 swb, bbw
1968 Camaro coupe
1968 camaro convertible (cream puff)
1972 K10 swb 4wd SuperCheyenne
SuperCtruck is offline   Reply With Quote
Old 07-21-2016, 12:08 AM   #2
Captainfab
60-66 Nut
Re: Upper Radiator Hose and water neck??
With the oil fill tube in the intake manifold, you will need to use the straight, forward facing thermostat housing. For the upper hose, you can use either the reproduction pipe and hose couplings or use a solid rubber hose. The solid hose many have used is Car Quest #20607. Other manufacturers use a similar number.
Old 07-21-2016, 12:51 AM   #3
jtrichard
Keep in mind stock is the steel pipe with short hoses and the 20607 hose is NOT for these trucks but fits pretty well
jtrichard is offline   Reply With Quote
Old 07-21-2016, 09:42 AM   #4
LT1 Burb
LT1 Burb's Avatar
Here you go
LT1 Burb is offline   Reply With Quote
Old 07-21-2016, 02:36 PM   #5
pimpston65
pimpston65's Avatar
Originally Posted by LT1 Burb View Post
Here you go
Sorry for thread jumping. Nice rad cap, can you post a closeup??!
pimpston65 is offline   Reply With Quote
Old 07-24-2016, 06:48 PM   #6
SuperCtruck
Thanks, now I'll go out and grab these hose and water housing
It does look cool but thanks for the heads up
Here you go
Cool pic, looks good
1964 C10 swb, bbw
1968 Camaro coupe
