Old 07-23-2016, 02:01 AM   #1
Old Roadie
Fuel Tank relocation
I have a 67 c10 Long bed that I recently had the fuel tank removed from behind the seat to under the bed behind the rear axle. The fuel cap sticks out from the side of the truck about 4". The tank was mounted under the frame with straps that are about 2" short on one side. I have not been able to fill the tank with out slowly squeezing the trigger on the pump. I am concerned about the tank being inches above the ground with nothing to protect it. Should I be concerned?
Old Roadie is offline   Reply With Quote
Old 07-23-2016, 02:08 AM   #2
Old Roadie
This is the other side
Old 07-23-2016, 05:45 AM   #3
GR8-68
GR8-68's Avatar
Re: Fuel Tank relocation
Personally I wouldn't like that at all, way to close to the ground and I don't like how it fits neither. I also bought a relocation kit and personally will probably not even try putting it in my frame cause I don't like how it even looks sitting in the box, cheap and cheesy. There are some good looking tanks out there and I personally will be purchasing one of them. Do a search on the forum here and you will see some good looking relocation kits
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-23-2016, 07:54 AM   #4
Old Roadie
I have seen some nice looking kits and installs. Unfortunately for me, mine is not one of those. I am in the process of having these issues corrected.
Old 07-23-2016, 08:02 AM   #5
Old Roadie
This is a pic of the new and old gas caps.
Old 07-23-2016, 08:39 AM   #6
Grumpy old man
Grumpy old man's Avatar
Hard to see is it sticking out of the bedside ?
Old 07-23-2016, 08:56 AM   #7
Old Roadie
Sorry here is a closer view.
Old 07-23-2016, 05:49 AM   #8
In The Ten Ring
I would change that set up too! It looks badly done and way too close to the ground.
Now that I plan to build my own tool box, I am not so concerned about the gas tank behind the seat. If I ever do relocate my tank, I'll have a custom tank made and try to use the side marker light as a fuel filler location.
In The Ten Ring is offline   Reply With Quote
Old 07-23-2016, 06:04 AM   #9
Grumpy old man
What size tank is it ?
Old 07-23-2016, 06:12 AM   #10
GR8-68
GR8-68's Avatar
This may be an option also, measure your height from the top of the mounting flange to top of tank then from top of frame to bottom of bed and see if there is enough clearance to relocate the relocation
Larry
"Project 68"
paypal.me/ldgrant
Old 07-23-2016, 07:56 AM   #11
Old Roadie
I had a shop do the relocation and it is back with them currently. Waiting to see the fix.
Old 07-23-2016, 07:51 AM   #12
Old Roadie
It is a 21 gallon I believe.
