Old 07-25-2016, 10:34 AM   #1
AbigailAmelia
AbigailAmelia's Avatar
Reattach drip rail temporarily on 1977 GMC
Hello,
Perhaps in the process of sanding and clear-coating my truck, a previous owner removed and then partially replaced the drip rails around the doors. The passenger side is tacked on with a few screws, the driver side trim is sitting behind the bench seat.
I found these threads about reattaching this type of trim.
Technical page http://forum.73-87chevytrucks.com/sm...c,24859.0.html
Original article: http://forum.73-87chevytrucks.com/sm...?topic=24752.0
My question is, should I go through all this now? I'm enjoying the "As Is Azure" + patina + clear coat + black paint job for now, but I will probably get her exterior painted/restored within a year (budget allowing!).
Is there a good way to attach this molding that will allow for easy-enough removal when needed? But if the rail isn't attached flat to the door, does it serve any purpose in the rain?
(Not sure why my photos rotated when I uploaded them; the originals are fine.)
Thanks!
Michelle
"...We won't live forever. Make sure you accomplish what you were put here for.”
Abigail Adams (First Second Lady, Second First Lady)
1977 GMC K25 Sierra Classic Long bed "Abigail Amelia"
1986 Jeep CJ7, 1973 Chevy K5 Blazer (Hubby's projects)
AbigailAmelia is offline   Reply With Quote
Old 07-25-2016, 11:24 AM   #2
Matt Man
Matt Man's Avatar
Re: Reattach drip rail temporarily on 1977 GMC
I would throw them back on. If you don't have them while it rains, water will fall down and hit the seat/floor. I used 3M tape and new Stainless screws. I have pictures in my build thread in my signature.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 08-04-2016, 01:44 PM   #3
Gmc.guy
Gmc.guy's Avatar
^^ what he said. I use a 5/16 (I think) wrench to remove/ replace the screws. You don't mangle anything that way. Put the seal tape on and start each screw a couple turns and start in the top corner and go down and forward with the screws. It's easy to manage that way and lay it flat. A small socket on it is too tight or a Phillips doesn't work too well either
-Cody
Gmc.guy is offline   Reply With Quote
1977 gmc, drip rail, molding
