07-26-2016, 12:33 PM | #1 |
Hydroboost with Rack and Pinion
I've read through numerous threads on here and read dozens of articles, but can't seem to find specifics on a hydroboost working with a rack and pinion system. I've contacted CaptainFab but he said he only makes the adapter plate, doesn't know much about the HBs and how they work.
Here is my setup. LS3 with Holley TC pump for LS engines. No Limit Eng rack and pinion. I can get a hydroboost remanufactured pump from Rock Auto for just about any year it was offered in a GM truck or Astro van. My questions are: 1. If someone has successfully used HB with a TC pump and rack, can you send me details and lessons learned? 2. Is there a particular year or part number for an HB that works better than others? |
07-26-2016, 03:16 PM | #2 |
Re: Hydroboost with Rack and Pinion
I would contact no limit , they should have your answers
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
07-26-2016, 03:28 PM | #3 |
I just converted to HB brakes, but I have the stock steer gear. There is a lot of good info on pumps, pressure and flow here:
http://www.pirate4x4.com/tech/billav...ng/index2.html If you get the pressure and flow specs from No Limit you might be able to determine if the TC pump will cut it.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
Tags |
hydroboost, rack and pinion |
