Small change, big difference
Who knew moving the exhaust tips would do so much?
Exhaust exited out the side, right behind the rear wheels. that created two issues: -Every time I pull into the garage, during the last two feet all the exhaust is blowing inside, making the whole garage stinky. -When I pull up to get a cup of coffee at a local drive-through, the exhaust echoes between the brick wall and bed of the truck. Too loud. I don't want the exhaust straight out the back, as I tow a trailer occasionally. The solution: Moved the tips out to the corners, under the bumper, angled out slightly, with a 45 degree downturn. Truck still has the same V8 loping idle, but after spraying the exhaust with high-heat rattle can of flat black paint, it is pretty much invisible. Start the truck, and the exhaust is already blowing outside the garage. Couldn't be happier. |
Re: Small change, big difference
It's totally incorrect for our trucks, but I run mine back out under the rear bumper... and it's a 133" Longhorn! Can't get much further away than that.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
My 'Burb has duals pointing straight out the sides behind the wheels, and I'll probably always leave it that way just because it's the sound I remember since I was too young to remember. My '85 had them straight out the back when I got it - love the look and don't mind it when towing but when I have the tailpipes redone I intend to go out the sides, as well, partly because it's factory and partly because I remember dad's '86 with the stock exhaust plus some oval, early 70's Chevelle tips my grandpa put on it on a whim. I keep quiet mufflers on my stuff and don't mind exhaust, but to each their own. Davepl, I dig the longhorn!
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Really? ....It makes the whole garage stinky? ....I never considered that a "bad" smell myself, I bet a Prius wouldn't do that. |
