08-02-2016, 11:25 PM | #1 |
IFS or Mustang II front end applications?
I have a 62 C20. I was told to check out Mustang II IFS or other IFS. Can anyone recommend one? I've found 63-87 applications but nothing for 60-62 yet.
Posted via Mobile Device |
08-03-2016, 01:07 AM | #2 |
Re: IFS or Mustang II front end applications?
60-62 have the same frame rail width in the front as 63-87 so if it fits 63-87 it will fit 60-62 just a bit more work, holes need to be drilled and some other stuff. Why do you want a mustang 2 IFS? Check out dropmembers made by companies like cpp and chopping block
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
08-03-2016, 01:33 AM | #3 |
60-66 Nut
What is your reasoning for changing the front suspension? Is there a reason you don't want to use a '71-'87 C10 front suspension?
08-03-2016, 08:38 AM | #4 |
For the price of the IFS I can't see how I could go wrong. By the time I find a front end out of a newer truck I'll end up having to buy all new replacement parts (calipers, rotors, coil springs, shocks, control arms, etc) which will cost almost triple what I can spend on some of the IFS I'm finding online.
08-03-2016, 09:47 AM | #5 | |
I seriously doubt a mustang ii conversion would cost less than a cross member swap, unless someone is giving you one for practically free. What are you plans/goal for this truck? Factory height, lowered cruiser, bagged truck, slammed race truck?
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car) 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
08-03-2016, 12:03 PM | #6 | ||
I'm just glad to be here!
New parts for 1977 Chevrolet C10 front suspension (RockAuto pricing) Calipers Loaded with pads Raybestos $45.88 Calipers Loaded with pads Raybestos $45.88 Rotors #5006R Raybestos $42.79 Rotors #5006R Raybestos $42.79 Wheel Bearings Inner, SET5 Timken $5.77 Wheel Bearings Inner, SET5 Timken $5.77 Wheel Bearings Outer, SET3 Timken $5.40 Wheel Bearings Outer, SET3 Timken $5.40 Wheel Seal 8835S Timken $1.87 Wheel Seal 8835S Timken $1.87 Brake Hose Front Right Raybestos $11.58 Brake Hose Front left Raybestos $11.58 Control Arm Bushing Upper, K6138 Moog $10.59 Control Arm Bushing Upper, K6138 Moog $10.59 Control Arm Bushing Lower, K6137 Moog $15.57 Control Arm Bushing Lower, K6137 Moog $15.57 Ball Joint Upper, K6136 Moog $26.79 Ball Joint Upper, K6136 Moog $26.79 Ball Joint Lower, K6117T Moog $22.79 Ball Joint Lower, K6117T Moog $22.79 Shock Front, #33033 Monroe $20.79 Shock Front, #33033 Monroe $20.79 Idler Arm K6096T Moog $24.79 Tie Rod Inner, ES409LT Moog $15.56 Tie Rod Inner, ES409LT Moog $15.56 Tie Rod Outer, ES409RT Moog $15.53 Tie Rod Outer, ES409RT Moog $15.53 Tie Rod Adjusting Sleeve ES2004S Quick Steer $2.41 Tie Rod Adjusting Sleeve ES2004S Quick Steer $2.41 Steering Gear, Power Reman. #277512 A-1 Cardone $132.79 Total: $644.22 Plus the front suspension from a junkyard, plus new lowering springs, I don't see how you could go over $1000.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-03-2016, 01:27 PM | #7 | |
One of the main reasons why I love this forum. Thanks for sending all the info below. I currently have a front end from a 67. Getting the drop spindles for that plus all the parts below is where I found the cost to jump over $1000
08-03-2016, 01:29 PM | #8 | |
If I were to find a 77 front end does it bolt right in to a 62 frame?
08-03-2016, 08:50 PM | #9 |
I used a Fatman Fabrication in my 66 c20. Was an easy install and drives nice. Bolt in hub to hub front end with mustang II springs, rack, disc brakes, 5x5 Chevy bolt pattern. Uncertain what they have for 62 though.
08-03-2016, 04:59 PM | #10 |
Well for that $650 build the torsion bar front end well... a few extra $$ for upgrades. I am on the pro bar bandwagon after I ditched mine. Now there are more companies selling parts for them. Softer ride and adjustable height.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-15-2017, 12:49 AM | #11 |
Any chance you know what websites offer upgrades for torsion suspension?
02-16-2017, 07:10 PM | #12 |
I left the t bars in mine, added a sway bar and the truck rides beautiful down the highway. Sway bar run you around $200 bucks and there are a couple of threads on here regarding sway bars for the 60-62's.
Don't think I could win a race around the track in this truck but for everyday cruising, I like the ride. Plus, the truck tracks 100% straight down the road even on slightly bumpy roads and there's something to be said about that. I wish I knew why everyone was so eager to get rid of these t bar rides. Maybe I'm missing something...maybe someone could explain it to me one day.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
02-16-2017, 08:15 PM | #13 | |
Appreciate the feedback. I'm leaning towards restoring the existing front suspension now. I don't need something for sport. Its just to cruise and look good. I know I can lower the truck using factory t bars too. I just can't find any information on how to upgrade or replace the existing parts.
08-03-2016, 09:45 PM | #14 |
I would feel safer with a truck suspension rather than one out of a 1/2 size car
perhaps in a Model "A" Ford or something along those lines if that is your thing and even there I would still prefer a straight axle ron |
02-16-2017, 10:37 PM | #15 |
You can not replace the actual torsion bars or lower control arms. But you can replace the spindles, shocks, the ball joints and the tie-rod ends. If you are not planning on bagging it or lowering it more than 5-6 inches in the front I would stick to the torsion bars. Just a warning the ball joints for a 60-62 can be expensive.
02-17-2017, 12:34 AM | #16 |
A few years back, there were ZERO parts for these front ends, now CPP and McGaugheys offer drop spindles for these trucks. If you plan to use McGaughys drop spindles, you'll need to use their brake kits as well. I think the whole kit is about $600.
If you plan to go a Willwood Route, you'll need to go the CPP drops as the Wilwoods won' won't mount on the McGaugheys. Forest is right, the ball joints are more pricey but not ridiculously bad. Get USA made parts. On my torsion bars, about 8 to 10 turns will lower my truck about 1/2". I lowered my truck about a year ago and have not messed with those t bars since. I actually like them...a bit soft but still nice! .QUOTE=forestb;7861273]You can not replace the actual torsion bars or lower control arms. But you can replace the spindles, shocks, the ball joints and the tie-rod ends. If you are not planning on bagging it or lowering it more than 5-6 inches in the front I would stick to the torsion bars. Just a warning the ball joints for a 60-62 can be expensive.[/QUOTE] Posted via Mobile Device |
