Old 08-03-2016, 03:19 PM   #1
richlaw1
Vin Number Check
does anyone know how to decode the VIN on a 55 to determine original color/trans/ etc?
for example, mine is M2550023608
richlaw1 is offline   Reply With Quote
Old 08-03-2016, 03:55 PM   #2
58APACHEE
58APACHEE's Avatar
Re: Vin Number Check
try looking at this, it might have it in there i think
https://www.gmheritagecenter.com/doc...2nd-Series.pdf
58APACHEE is offline   Reply With Quote
Old 08-03-2016, 06:46 PM   #3
mr48chev
mr48chev's Avatar
Paint codes are there but I didn't see where to find them. I did find an answer to another member's question on his front axle and alignment though.
My ongoing truck projects:
Old 08-03-2016, 06:55 PM   #4
58APACHEE
58APACHEE's Avatar
try this one seems more clear
http://www.bestintexas.com/cars/55codes.htm
never mind this is for cars
Old 08-03-2016, 07:53 PM   #5
mr48chev
mr48chev's Avatar
That is the other thing on Tri-5 Chevrolets there is so much on the cars that you really have to sort though to find the truck
Old 08-04-2016, 08:50 AM   #6
1project2many
Howdy.
Your VIN follows the format for USA VIN for second series 1955 Chevrolet trucks.
M2550023608
No "V" = Six cylinder engine
M = 3200 (long bed 1/2 ton)
55 = 1955
O = Oakland CA Assembly Plant
023608 = 23,607 long bed half ton trucks built at Oakland before yours that year.
I have not yet found a source able to provide option <> VIN correlation for the TF trucks. Maybe someone here has more info. GM's Heritage Center said they couldn't get any vehicle specific information for Chevrolet that far back as the records just weren't available.
For color, you can look under voltage regulator, inside wiper cowl, under pieces or weatherstrip, etc for traces of original color. Maybe can trace VIN back to state issuing original registration to see what color was on reg. Engine and trans options would take some detective work but a guy with a little patience could swap all the pieces to convert a truck from three speed to four (or vice-versa) fairly easily. Locate date codes on the trans, block, rear axle, etc to determine which parts if any are not the correct age for the truck.
Here are some resources:
http://www.trifive.com/forums/showthread.php?t=34093
http://www.trifive.com/forums/showthread.php?t=57115
http://www.stovebolt.com/techtips/vin/vinbuster.html
http://chevy.oldcarmanualproject.com...sm0serial1.htm
1project2many is offline   Reply With Quote
Old 08-04-2016, 09:50 AM   #7
richlaw1
thank you........
I see that it's a 3200 but I have a short bed
I believe they made 3200s with short bed in 55 and 56.......
can anyone verify this??
Old 08-04-2016, 10:24 AM   #8
1project2many
http://chevy.oldcarmanualproject.com...5ctsm0load.htm
3200 is 123" WB while 3100 is 114"WB. Someone has likely moved the cab to a short frame. Check the last link I provided previously to see where OEM serial #'s are located.
Edit: VCCA chat might be a good source of info.
http://vcca.org/forum/ubbthreads.php/forums/7/1/1958-60
Old 08-04-2016, 12:25 PM   #9
OrrieG
OrrieG's Avatar
The factory spec manual only shows the longer wheelbase for 3200. There are two vin locations on the frame. Both are on the top of the top rail. One is located just in front of the steering box, that sometimes get removed. A second in under the driver seat/step. Hard to read but you can get an impression using graphite and thin paper or chalk and a mirror.
Old 08-04-2016, 01:09 PM   #10
richlaw1
thank you.........will do!
