Old 08-04-2016, 01:01 AM   #1
Orence1
Orence1's Avatar
Fuel gauge/sending issue
Fuel gauge has started bouncing around. I have a new LMC rear tank with sender installed about 1 year ago. The fuel gauge was replaced a few years back. The tank is about 1/4 full. It pegged to the right for a few minutes on the way home today but bounced back to 1/4 when I got into the shop. Should I be looking at my ground, sending unit or is the gauge going out again? Any suggestions appreciated.
Orence1 is offline   Reply With Quote
Old 08-04-2016, 01:49 AM   #2
truckster
truckster's Avatar
Re: Fuel gauge/sending issue
Look for anywhere the sending unit wire might be grounding out. The gauge goes to ground through the sending unit - that's where the resistor is. If it's bouncing to full, it's likely finding ground somewhere before it gets to the sending unit.
truckster is offline   Reply With Quote
Old 08-04-2016, 02:29 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Check the wire from sending unit to fuse panel (light brown). Most likely it is corroded as it passes beneath the sill plate. Also make sure the connection is tight at the sender. With the key in the "on" position, try to wiggle the wire and see if the gas gauge needle moves.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-04-2016, 12:14 PM   #4
Orence1
Orence1's Avatar
Thank you gentlemen. I will follow up on your suggestions.
Old 08-04-2016, 12:42 PM   #5
rdhowe2006@yahoo.com
rdhowe2006@yahoo.com's Avatar
I'm having a problem with mine also. I replaced mine a couple of years ago with an LMC tank. It has been working fine until about a month ago. The tank is half full but my guage shows empty. Could it be the sending unit or something else. Any help of what to look for would be greatly appericated. Thanks Ron
rdhowe2006@yahoo.com is offline   Reply With Quote
Old 08-09-2016, 10:53 PM   #6
leddzepp
Moderator
leddzepp's Avatar
The float attached to your sending unit has probably failed.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-11-2016, 11:26 AM   #7
snipescastle2
snipescastle2's Avatar
Talking Re: Fuel gauge/sending issue
I just found the pins on the back of the cluster connector needed to be bent out a little to make a good connection, the other possibility could be a small break in the copper trace of your Printed circuit board, making intermittent contact. Hope this helps!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-07-2016, 10:28 PM   #8
Any help would be appreciated.Thanks Ron
Old 08-09-2016, 10:18 PM   #9
Ttt
Old 08-11-2016, 08:07 PM   #10
Ttt
