Need GMC Engine Help!
So I've been having trouble with the GMC 351 V6 in my 5000. It's been lacking power incredibly badly going up hills, bogs down without any load on the truck bed. I can mat the accelerator uphill and there is no difference.
I've done everything to the engine except for the distributor cap. I've cleaned the cap contacts and checked the spark and it is good. Points are set at .016, timing is set at 5deg, new coil, valves have been adjusted, cylinder compression is 120psi, air cleaners clean, fuel pump is good, fuel filter is new, etc... It has the "Handy Governor" thing on there too. Removed it and set the spring by the GM book (maybe remove it all together)? So right now I'm leaning towards either timing or too much fuel, but I'm not sure. Any ideas??? I'm using it to haul tractors to a show this weekend so I gotta figure out something! ![]() |
One foot in front of the other
![]() Join Date: Aug 2008
Re: Need GMC Engine Help!
You been to this website?
http://6066gmcguy.com/performance.html |
#3 | |
You do have a vented gas cap right?
also check for vacuum leaks around intake and if v/advance is working
ron |
#6 | |
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#7 | ||||
I believe I do but I'm definitely going to check and make sure it's venting! Quote:
Loose power?? Since the day I first drove it across town last year. I was real boggy and I figured with all the work I've done to it it would go away. It's gotten a lot better since then but the engine still face plants on a hill. It does run nice aside from that, if I listen under a load the exhaust is even toned, no funny noises or sputtering. Down hill it backfires and spits. Although on occasion coming up a hill it will skip a few beats, like someone shut the ignition off for a second then turned it back on. So maybe it's lacking fuel? I ordered a new distributor cap this AM, going to pick it up tomorrow morning and see what happens. And adjust that timing some. I'll let you guys know my findings.... |
#8 | |
#9 | |
#10 | |
the bolts at the intake to the heads can be tight but that doesn't mean that they can't leak. just spray a little wd40 around the base of the manifold and see or hear what happens
ron |
