Old 08-11-2016, 03:04 PM   #1
jr1000yarder
Need some side mirror measurements please
In need of some bolt hole locations for 69 Below the eyeliner mirrors. Hopefully Firstowner69 will chime in. Guess I need the top bolt hole location and the front hole location.
The doors I have had sport mirrors and noting to go off of.
Many, Many thanks, Rich
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 08-11-2016, 03:20 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Need some side mirror measurements please
I am "separated" from my truck until late next week and can't help until then. Someone else will probably chime in before that. The locations may be shown in the assembly manual if you have one.
FirstOwner69 is offline   Reply With Quote
Old 08-11-2016, 03:26 PM   #3
jr1000yarder
I do.......Thank you very much. I'll see if I can find it in the book.
IT IS WHAT IT IS
Old 08-20-2016, 01:59 PM   #4
FirstOwner69
For future reference...
The picture below is from the assembly manual. The measurements on my factory doors are VERY SLIGHTLY different from the manual and also from side to side.
Old 08-20-2016, 09:07 PM   #5
jr1000yarder
That's what I was told...was hoping to get some "REAL" measurements....
IT IS WHAT IT IS
Old 08-20-2016, 10:30 PM   #6
FirstOwner69
Hopefully, I can post "real" measurements tomorrow. However, by "very slightly different" we are talking a variation only 1/8" or less here and there from the measurements in the assembly manual. That probably wouldn't make any difference. As a side note, the factory attached the '69 mirrors with hex head sheet metal screws. Some of mine pulled out when the truck was only a couple years old thanks to an electric/telephone pole too close to the curb. I drilled the holes and inserted bolts. When I restored the truck, I drilled all the holes and used jack nuts with vinyl covered heads like those GM used in later years. This could have moved the locations on my doors slightly.
Old 08-21-2016, 08:09 AM   #7
Aus69c20
Aus69c20's Avatar
I can measure mine for you tomorrow. But I measure in metric so I don't know how useful that is to you.
It looks as though first owner has you covered, but if you want a second point of reference and you can read metric sing out.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 08-21-2016, 04:52 PM   #8
dazza
dazza's Avatar
My SPID shows DG4 and they are the shorter legged Below Eyelines. I'm guessing the ones in FirstOwner69's pic from the manual those would be the long legged version(D29?). Not sure if this will help or which you might have but here are measurements of my shorter versions.
Just realized yours is a 69, mine is a 72.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 08-21-2016, 08:17 PM   #9
FirstOwner69
Yup, yours are the 72 only version of the DG4s.
The ones in this thread are the 69-72 version.
Old 08-21-2016, 08:33 PM   #10
jr1000yarder
Thanks much. ..look forward to getting them. I have obtained NOS screws for them. Did they use nutcerts in The holes???
IT IS WHAT IT IS
Old 08-21-2016, 09:04 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Do the NOS screws have a "P" on top of the bolt? Screws just screw into the door sheetmetal. No nut or backing plate w these.
Old 08-21-2016, 09:16 PM   #12
jr1000yarder
Yikes.ok. ...yes I believe they do. I'll have to dig them out to verify. Came with nylon washersalso
IT IS WHAT IT IS
Old 08-21-2016, 10:12 PM   #13
FirstOwner69
As I mentioned in post 6, I replaced the original hex head sheet metal screws with jack nuts, a type of nutsert. I'd seen those used on a 79 Chevy van that I removed some mirror heads from (and the neat stainless bolts for the jacknuts). DeadheadNM is right on about the screws.
I got tied up today trying to replace a water pump on a 25 year old Mercury 150 HP outboard and totally forgot about the measurements until dinner. I will get some pics with measurements tomorrow when it's light out. I wish that Merc was as easy to work on as a SBC!
Old 08-22-2016, 07:13 PM   #14
FirstOwner69
Post Re: Need some side mirror measurements please
I have added the actual measurements from my '69 and keyed them numerically to the assembly manual page I posted previously (picture below). The biggest variation is the horizontal distance between the bottom screws. I tried taking pictures with tape measures to show the measurements, but, due to parallax and the risk of damaging the paint, I abandoned that method.
If I were to drill doors with no existing holes, I would follow the assembly manual.
In case the measurements in the picture are not clear, they are:
#1 Left 1-3/4" Right 1-13/16"
#2 Left 2-3/4" Right 2-7/8"
#3 Left 9" Right 9"
#4 Left 8-3/4" Right 8-13/16"
#5 Left 13-7/16" Right 13-1/8"
#6 Left 9-5/8" Right 9-1/2"
EDIT: Corrected error in picture.
Old 08-22-2016, 07:19 PM   #15
jr1000yarder
Looks good, I'll be drilling them soon so I'll post questions if I have any.
Thanks very much!!!!!!!!
IT IS WHAT IT IS
Old 08-22-2016, 07:23 PM   #16
FirstOwner69
Note that I corrected a dimension (#5 left) in picture.
Old 08-22-2016, 09:06 PM   #17
jr1000yarder
Yes sir, got it!!
IT IS WHAT IT IS
