Old 08-21-2016, 02:11 PM   #1
jayoldschool
Moderator
My bed is a pond
65 LWB fleet. My bed is holding water after a rain. A lot of water. It will drain really slowly over a couple of days (drip at a time) as well as evaporate. The bed is a bit canted so it pools in the front passenger corner. I guess I need a drain hole. Should I put it through the corner of the wood, the front panel, or the bed side?
jayoldschool is offline   Reply With Quote
Old 08-21-2016, 03:54 PM   #2
jayoldschool
Moderator
Re: My bed is a pond
Had a quick search for "water in bed" and found someone with a similar issue on a 67-72. Looks like there is supposed to be drain holes in those trucks, so I'll replicate them on mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=494735
Old 08-21-2016, 04:02 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I'd go through the wood. Steel will rust after drilling. Best to go in the 3/4" range so you can poke your finger through now and then when it begins to clog up with leaves and such. Both sides of the box so it can drain either side.
Old 08-21-2016, 06:39 PM   #4
jayoldschool
Moderator
Yes, it will be a lot quicker to drill through the wood, too!
Old 08-22-2016, 12:23 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Never had that problem! Partly cause the wood in my GMC's bed is 50 years old!
Old 08-22-2016, 06:49 AM   #6
jayoldschool
Moderator
Yeah, my bed wood is actually plastic TREX. Great for outdoors, also great at being waterproof... guess I should have cut a couple boards short! lol
Old 08-22-2016, 11:20 AM   #7
Praxiss454
Praxiss454's Avatar
Jay do you park on a downslope? When you cut your trex did you follow Paul's measurements? They call for a drain channel every so often.
I'm considering options for doing my bed and was thinking about trex so I'm interested in this pooling problem.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 08-22-2016, 04:25 PM   #8
forestb
forestb's Avatar
I have never had that problem but that is probably because it no longer rains in Los Angeles.
forestb is offline   Reply With Quote
Old 08-22-2016, 09:02 PM   #9
jayoldschool
Moderator
Level ground, but my truck is slightly tilted to the front like most stock suspension long boxes.
Yes, used GMC Paul's cuts. Don't remember any drain cuts, just the cuts for the strips.
