Old 08-21-2016, 03:34 PM   #1
byates2
byates2's Avatar
Vacuum Pump Installation
I bought a vacuum pump for my power brakes because of the performance cam i have. I have installed everything and the pump is in place, just need to run the hoses.
There are 2 options on the directions. One is leaving the exhaust port open with no line attached to it and then running a hose from the intake vacuum and teeing up with vacuum pump vacuum port and running to the brake booster.
The other option is running a line straight from the vacuum pump port to the brake booster, and a line from the exhaust port to the intake vacuum.
I havent been able to find much info on this. What are the differences in the 2 options?
Should i have a hose runnning from the exhaust port to the intake vacuum or just have a line going from the vacuum to the vacuum pump and then to the brake booster
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 08-21-2016, 06:44 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Vacuum Pump Installation
Exhaust port to intake would probably keep the bugs out of it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-21-2016, 06:53 PM   #3
byates2
byates2's Avatar
What do you mean bugs? actual bugs or problems in the engine?
The exhaust port has a wire mesh screen protecting it. I was wondering if there are any advantages going either way?
Would pushing more air into the intake from the exhaust port benefit at all?
Seems like if i have the vacuum inline with the engine it might take some strain from the pump. Dont know though
Old 08-23-2016, 11:45 AM   #4
snipescastle2
snipescastle2's Avatar
Talking Re: Vacuum Pump Installation
I installed an Electric Vacuum Pump on my truck from a 2002 Audi A4, I made a vacuum reservoir out of a 2 lb. Oxygen bottle, I plumbed the pump to a check valve, tee'd that into the main vacuum hose, going to both the reservoir and the brake booster, and then onto a vacuum switch set for 22" of vacuum, then to the original type check valve on the booster. I had originally wired it directly to the vacuum switch, but the settings on it either cycle the pump off and on rapidly, or it stays on continuously. I think I'm going to wire mine through the brake switch to come on when I hit the pedal only, otherwise it just gets too hot. but, these pumps make vacuum rather easy and I got mine to make 25" vacuum by itself. Just an idea.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
