Old 08-21-2016, 09:53 PM   #1
sameyrasmea72
sameyrasmea72's Avatar
Hub cap ????
Is there any way to tell if these are NOS or new? Do the even reproduce these? Thanks.....Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 08-21-2016, 10:06 PM   #2
jocko
jocko's Avatar
Re: Hub cap ????
Jason, I don't believe they are repro'ed. I bought a used NOS uninstalled set that looked as clean of chevs - if never installed, they look new. Those could be as "late" as mid-80's?? Those are perfect. How's old red shortie comin along? Haven't seen you in a while!
Old 08-21-2016, 10:15 PM   #3
sameyrasmea72
Re: Hub cap ????
..... How's old red shortie comin along? Haven't seen you in a while!
Last Wednesday was the last time I've seen them!!!!
72 Cheyenne Super
Old 08-21-2016, 11:40 PM   #4
68bowtie
68bowtie's Avatar
Re: Hub cap ????
wow. i am sad just looking at your pictures. at least they are together...
Old 08-22-2016, 12:31 AM   #5
sameyrasmea72
Re: Hub cap ????
Very sad!! At least the twins stayed together
72 Cheyenne Super
Old 08-22-2016, 06:21 AM   #6
Re: Hub cap ????
I guess what has to be has to be.
The caps I go by looking at the back rim. You can tell if they've been pried on to remove. If they haven't been removed they were never installed
Old 08-22-2016, 07:14 AM   #7
sameyrasmea72
Re: Hub cap ????
Tim, I am sure they have never been on a truck but I am going to try to sell them and I did not want to represent them as GM if they were repos. Any idea what they are worth?
72 Cheyenne Super
Old 08-22-2016, 12:18 PM   #8
davepl
davepl's Avatar
Re: Hub cap ????
Depends how rare they are, how many years they were used (and hence demand). I paid $1500 for a set of NOS 1970 caps (one-year or two-year only) for an 8-bolt wheel, and there were 62 other bidders right behind me. It still hurts, but I have them.
Or if they're off a mid-80s van, maybe 1/10th of that!
Either way they're very minty, even nicer than my NOS set. Gotta be several hundred at least if they're used on trucks.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-22-2016, 03:38 PM   #9
sameyrasmea72
Re: Hub cap ????
They are pretty run of the mill. I'm just wondering what I should ask for them.
72 Cheyenne Super
Old 08-23-2016, 10:04 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Hub cap ????
Fairly common cap. Being for a 1/2 ton I would put them in the $150-$250 range. On e-bay they could go for more on the right day, but I think they will be on the lower end of my opinion.
I don't think these are reproduced either.
Are you getting out of the trucks? Do you have a clean roller I need to come get this winter?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-24-2016, 01:19 AM   #11
sameyrasmea72
Re: Hub cap ????
Yes I'm pretty much out of the truck business. Down to a bunch of small parts.
72 Cheyenne Super
Old 08-22-2016, 08:04 PM   #12
Re: Hub cap ????
Dave, your hubcaps are 69-72, then there were 73-75. That's it! Then came this style from 76-91. The thing is, basically only two types of hubcaps were made for Chevy/GMC that fit nub-type wheels on 3/4t... 69-91!. In prior years there were nub-type 1/2t caps, but not for too long prior.
Old 08-22-2016, 09:02 PM   #13
davepl
davepl's Avatar
Re: Hub cap ????
Thanks - I was under the impression there were two types of caps in 69-72 and that one was stainless and one was chrome. Can someone break it down by year for me?
Any different for 8-bolt?
Old 08-22-2016, 11:36 PM   #14
sameyrasmea72
Re: Hub cap ????
So does ANYONE know a fair price to ask for these??????
72 Cheyenne Super
Old 08-23-2016, 02:20 PM   #15
davepl
davepl's Avatar
Re: Hub cap ????
Put them up for a 2 week auction on eBay with no reserve. What they sell for is what they're worth, really.
Old 08-24-2016, 10:28 PM   #16
factorystock
factorystock's Avatar
Re: Hub cap ????
My observations: First issue factory '69 thru early '72 caps were chrome over brass construction. Notoriously weak, they crack and dent very easily. A switch was made sometime in '72 to stronger stainless. Some assembly plants kept installing chrome caps till supply exhausted. Now, if you went to the GM parts dept. back in '69, '70 ,'71, you would get chrome over brass. If you went to the GM parts department in the mid 70's, chances you would get them in stainless steel ( the method of construction till '75), unless they had the older unsold chrome caps laying around. This comes to a whole other topic of NOS parts made in the early 70's vs. NOS parts made in the '70's or 80's.
factorystock is offline   Reply With Quote
Old 11-09-2016, 09:31 PM   #17
factorystock
Re: Hub cap ????
Case in point. http://www.ebay.com/itm/Vintage-1970...lXv4PO&vxp=mtr Not mine. What was GM thinking making caps out of such weak material? Ford used stronger stainless steel through out the '67- '72 era.
Old 08-23-2016, 08:05 AM   #18
Re: Hub cap ????
I see prices all over the place. They are going up all the time. I see the 69-75 caps go for $200 or more for exc. cond. I'd think double that for N.O.S. On these later caps I'd venture to say $200-300. Let others work off of that with opinions and offerings.
Dave, I've never heard the rhyme or reason for some being stainless and some chromed steel. The belief was always pre-73 steel/post-72 stainless, but we now know of deviations from that...in both directions. I would assume the mixing & matching occurred closer to '73 and just a matter of supply. We only know the year by the convex with black paint vs concave unpainted. We don't know how many jobbers there were at what time and who used what material. We also don't know if hubcaps are the original ones from new or have been replaced. It's all myth until we talk to someone who was involved in GM parts supply at that time. I doubt any records would reflect such info. GM probably wasn't specific on the materials, just called for "bright work". I dunno
Old 08-25-2016, 11:30 AM   #19
Re: Hub cap ????
All the N.O.S. 8-lugger caps I've had where 69-72 chrome. I don't think they made a surplus of the late-72 style stainless caps. I wonder if they went straight to all stainless once delivered, used chromed surplus at the end when sales went so strong. They had to tool up and stamp for the '73 model change
Old 08-25-2016, 12:25 PM   #20
davepl
davepl's Avatar
Re: Hub cap ????
NPOS. New Pseudo-Old Stock.
But in seriousness, yes, I agree there's a difference between a part made during the production run and service parts put into the queue at a later date. Because for some reason they never seem to be quite right or the same quality! Dash clusters, door handles, and so on are prime culprits...
